Old 01-25-2016, 09:21 PM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM Pulleys by Z Industries
ADM Performance, LSAConversion.com and Z06 Parts Inc. are proud to announce our 2016 line up of
Supercharger Pulleys by Z Industries and ADM Performance.
ADM Performance called upon Drew Zimmer and his father to manufacturer our new Premium line of
LSA, LT4,LS9, LSA Conversion and Magnusun Multi piece supercharger Pulleys .
Our new lineup will showcase these new benefits of the previous models:
GRIPTEC® MICRO
GipTec® Micro is a micro machining process. Our micro machining capabilities are near limitless and we apply our technology to give the target component the desired friction coefficient that optimizes the safest most aggressive gripping force possible. Our multidirectional machined ridges and valleys offer up more than just maximum gripping force they also act as escape ducts for trapped air and debris further helping in the mating of the target surface and belt. Patent Pending
Belt slip is a very common issue on supercharged components. In fact some units cranking out as much as 14-16 psi can take up to 200hp to drive. Often the drive systems are plagued with slippage issues and builders find themselves moving to noisy cog systems, where belts have shorter life spans, are difficult to find at just any parts store and they can create more heat through the frictional movement of the cogs.
Belt slip isn't always noticeable. Often belt slip is noticed when the system squeals, squeaks or boost falls off. Did you know that naturally the belt can slip a very small percentage even on NA vehicles, one major factor to belts wearing. Belt wrap does play a key factor in minimizing belt movement but when it comes to driving a supercharger is hard to fully eliminate with just surface contact. Systems runing 3.4 upper pulleys can see as much as a 1.5 psi gain when matching size for size puleys.
Whether you are running 6 psi or 20+ psi you are slipping if you are not running GripTec®
Pro's to using GripTec®
• Increased boost and supercharger performance size for size pulley
• Reduce or eliminate belt slippage on the applied component
• Increase belt life from not slipping over and over again
• Eliminate belt squeaks common when shifting hard
Con's
• To much boost for current engine tune. Adjustment may be required.
About ZPE
ZPE Inc. was founded in 2013 but is no stranger to the automotive world. Our parent company Z-Industries was founded in 1984 and Incorporated in 1987. Z-Industries Inc. offers advanced tuning and emissions services to the aftermarket and OEM industry. ZPE offers advanced engineering solutions for applications in both the automotive and the machinery industry. Our new found love for designing and patenting has brought several new technologies to the automotive and machine industry with more to come. Our commitment to our customers is to provide the highest quality components and service possible. Our standards of manufacturing are the highest possible and it shows in everything from the designs and quality of our parts to our custom packaging. We want to offer a quality that just doesn't exist in the performance world outside of ZPE, which is why we will continue to seek and develop new solutions and parts for years to come.
Andrew Zimmer
President
ZPE Inc.
ADM PERFORMANCE is offline   Reply With Quote
Old 01-25-2016, 09:54 PM   #2
Harley01
Drives: 2015 Camaro ZL1 (red hot)
ZPE Inc.......Z1C 2.45 LSA 2PC PULLEY SYSTEM W/PRO INSTALL TOOL KIT INSTALLS IN 45 MIN
They were at one time offering a removal tool to remove the supercharger pulley without pulling the snout. Then heating the new pulley with a bearing heater for installation. IE 45 minute install!! Are they still, if so I'm interested.
Harley01 is offline   Reply With Quote
Old 01-26-2016, 04:46 AM   #3
RedZL1
Drives: Victory Red ZL1
Are these grip tech pulleys up on your LSACONVERSION site now? And are they anodized black or raw finish like shown in video?
RedZL1 is offline   Reply With Quote
Old 01-26-2016, 06:20 AM   #4
ADM PERFORMANCE
They will be on our site in the next few weeks. The first group will be polished.
Old 01-26-2016, 11:43 AM   #5
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
ahhh I may hold out for the 2.50 black anodized order then
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 01-26-2016, 06:48 PM   #6
mtl-biker
Drives: 2010 Camaro SS
Hi
Did you ship to Canada
Thanks
Mario
mtl-biker is offline   Reply With Quote
Old 01-26-2016, 08:41 PM   #7
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Is this the same Z-industries as Ron Zimmer? He tuned my 87 GTA Trans Am back in the early '90s. Hadn't heard anything from him in a long time.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 01-27-2016, 12:04 AM   #8
GenF-GTS
Drives: none
Do these bolt up to the LPE 10bolt hub that we normally use when running a 2.55 2.38 etc
GenF-GTS is offline   Reply With Quote
Old 01-27-2016, 11:13 AM   #9
EvilZL1
Snake Eater
EvilZL1's Avatar
I kinda want to order now depending on the price lol guess I have to hold out for a bit longer
Old 01-28-2016, 02:34 PM   #10
BattleScarredSoldier
BattleScarredSoldier's Avatar
Drives: 14 Camaro ZL1, 87 Grand National
Will you also be doing lower pulleys?
Vengeance Racing + Cat and Muffler Delete > Viagra
BattleScarredSoldier is offline   Reply With Quote
Old 01-28-2016, 02:36 PM   #11
ADM PERFORMANCE
No. Ours are not the same unfortunantly
Old 01-28-2016, 02:37 PM   #12
ADM PERFORMANCE
His son is Andrew Zimmer. Ron Zimmer is no stranger to the industry
Old 01-29-2016, 03:05 AM   #13
I guess youre not sure about the lower pulleys yet? Lol. Looking forward to these upper pulleys being released, I have a 2.55 now but was always worried about going to a smaller pulley and having more belt slippage because of less contact area for the belt to grip. I believe Mr Jannetty pointed that out in a different post, and it makes perfect sense. With your design offering more grip on the area provided, I'd be willing to give a the upper pulley a try, even more willing to give the lower one a try too!
Old 02-11-2016, 10:08 AM   #14
EvilZL1
Snake Eater
EvilZL1's Avatar
2 week later....Hi any updates lol
