#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 04-08-2016, 08:34 AM   #1
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
OIL pickup tube bolt retention TSB?
Hey guys, I just got a call from my dealership (that I purchased the car from) calling me to tell me of a recall about an oil pick-up tube that can come loose and starve the engine. Has anyone else heard of this yet? He said it just hit his desk this morning. I'm going to make an appointment with my local dealership to have this taken care of ASAP. If anyone has access to the TSB and want to share that would be awesome.
Just checked Chevy's website and it's program # 2030990.
Might want to check your VIN here.
https://my.gm.com/recalls
Edit: Spoke with the local dealer, apparently they don't have the information they need (bulletin information) to order anything yet. I guess I'm going to have to take it easy. Little nervous to drive it now!
Here's helpful information since my thread was merged with TR6's thread. Thanks Turk.
Originally Posted by Tr6 View Post
THIS IS FOR 2016 CAMARO SS / 2SS MODELS ONLY. (Also for 2016 CTS-V's)
I know there is a pretty good size thread however, I figured I'd post this here as I do have the bulletin so it doesn't get lost somewhere in the thread and for people to find it easier. GM updated their dealership network SIS (service info system) over night. I called my dealership and made an appointment for monday morning. Make sure you get this checked ASAP as IF you do have it. It is a LONG and PITA process to implement the preemptive (or simply put, fix) process. It will require them to put the entire engine on a cradle to hold it up and get to work. On average, it's a 9 hour work and not everyone can do it, a gen 6 camaro/ c7 corvette specialized tech is the only one who can. So bank on a couple days at least, IF you have it.
Here is the entire Bulletin 30990 in PDF which you can download via my dropbox OR view it via the attached bulletin as PDF here:
https://www.dropbox.com/s/x2pefrimju...letin.pdf?dl=0
Also: Glen has posted here:
http://www.camaro6.com/forums/showpo...5&postcount=68
More info:
Originally Posted by trz174 View Post
Thanks very much for the detailed info. Unfortunately, I'm on the lucky VIN list so it's off to the dealer this week. If you want to check the pan for the raised number at home, you don't have to remove the aero pan. There are two quick ways to let you clearly see the number (or lack thereof).
1. You can see the raised number from the gap behind the crossmember on the passenger side. The gap is to the right in this photo. Use a good light or camera. This requires you raise the car to get into position.
2. Another method is to slide a camera phone up into the gap behind the crossmember and take a few photos. Obviously I'm using a lift, but this can be done without ramps in the driveway with a bit of stretching. Be careful not to hit the exhaust when reaching underneath.
Originally Posted by Glen e View Post
A master tech wrote me last night the fix is 10 hours.....and because not every tech can do this, the lines will be long in the service dept, get signed up early.
Prelim GM PDF here, looks simple but as turk says, getting the oil pan off is labor intensive..
Here's the PDF link in question.
http://www.camaro6.com/forums/attach...7&d=1460221740
SPARTAN sui is offline   Reply With Quote
Old 04-08-2016, 09:25 AM   #2
Greg_Di
Drives: 2016 Hyper Blue 2LT
No recall for my vin.
Hopefully everything gets fixed for you
Greg_Di is offline   Reply With Quote
Old 04-08-2016, 09:28 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
This looks to be just the V8....
Glen e is offline   Reply With Quote
Old 04-08-2016, 09:31 AM   #4
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
Yup just checked and mine is tagged :( If they are dropping the pan then you will get a free oil change too usually.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 04-08-2016, 09:36 AM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
My Vin wasn't recalled (yet). Jordans car was. I think it's the early run cars that are being recalled first, it would seem.
All the best,
Jared Royce
801.545.4215
Old 04-08-2016, 09:49 AM   #6
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
just checked and mine's ok. whew......at least for now I guess .
nancygrl is offline   Reply With Quote
Old 04-08-2016, 09:58 AM   #7
usmcfiredog
Drives: 2016 Black 2SS
I have the recall on mine too... Time to make an appointment
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Low Gloss Black 5 Spoke
usmcfiredog is offline   Reply With Quote
Old 04-08-2016, 10:04 AM   #8
SPARTAN sui
PC Technician
For you guys that have the recall for your Camaro, please post back if your dealership orders a part or schedules you for an appointment. According to the website, if it says remedy not available, it's not available. However it says incomplete for me, which conflicts with what my local dealership is seeing in their system. Curious.
Old 04-08-2016, 10:22 AM   #9
TSloper
Drives: 2016 Camaro SS
I'm guessing it is related to this...
Document ID: 4444434.pdf
My VIN is under the recall but my oil pan does not have the raised numbering called out in the bulletin.
TSloper is offline   Reply With Quote
Old 04-08-2016, 10:23 AM   #10
usmcfiredog
I don't see where it says remedy not available
Camaro 2SS
Black/Jet Black
A8, NPP, MRC, NAV
Old 04-08-2016, 10:35 AM   #11
shawn0138
Drives: 2016 Camaro 2SS 2014 Chevy Impala
My car has the recall as well. Will have to call my dealer and see when I can get it fixed.
shawn0138 is offline   Reply With Quote
Old 04-08-2016, 10:40 AM   #12
SPARTAN sui
PC Technician
My program status is INCOMPLETE; however my dealership has no fix information, which contradicts the website. According to the website, there should be a fix.
If the status field states “INCOMPLETE” and your vehicle is a Chevrolet, Buick, GMC, Cadillac, Pontiac, Oldsmobile, HUMMER or Saturn, please contact a Certified Service Dealer to schedule a service appointment or order parts. If your vehicle is a Saab, please contact an authorized Saab service center.
Old 04-08-2016, 10:50 AM   #13
Snowblind
Snowblind's Avatar
Drives: '16 2SS / '05 SRT10 Ram / '65 bu
Got me too, I guess I'm watching the oil pressure gauge until it gets serviced
H/C SBE 9.80@140 powered by Texas Speed
Snowblind is offline   Reply With Quote
Old 04-08-2016, 11:01 AM   #14
suzook
Drives: camaro
Ugh, mines tagged. I hate going to the dealership.
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
