Old 01-29-2017, 04:03 PM   #1
370zyzfr1
Drives: 2014 Camaro Zl1 Tripple Black!
how much hp increase from e85?
Quick question
I have done the jre 125 kit. I did a remote tune with Tes and dialed it in a few times and she runs really well.
18% OD
Headers
ID 850s
Rotofab
Fuel pump booster
Again everything in the 125kit
IF I Want to add E85 alone how much would that garner me for more power?
370zyzfr1 is offline   Reply With Quote
Old 01-29-2017, 05:37 PM   #2
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
Originally Posted by 370zyzfr1 View Post
Quick question
18% OD
Headers
ID 850s
Rotofab
Fuel pump booster
Here you go. Before and after true E85 with your mods but on a 10" pulley. Your injectors will work, your are going to need more fuel pump though. I would up your pulley size as well to get max gains and take advantage of the cooling properties and additional octane. Also, you should run a Flex Fuel sensor and tune to allow for variances in alcohol content between pumps. Fuel labeled as E85 varies between E50 and E85 true alcohol content.
2013 ZL1 CRT M6
__________________________________________________ ____________________________________
Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip.
Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60'
Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer.
crazydave is offline   Reply With Quote
Old 01-29-2017, 07:10 PM   #3
ObiZLWan
ObiZLWan's Avatar
That is some great gains!
2013 ZL1 Black #7128 2900 miles. Roto-Fab CAI, Elite CC.
ObiZLWan is offline   Reply With Quote
Old 01-29-2017, 08:24 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Seems to be almost a flat torq curve after the E85....nice.
Mods:
Old 01-29-2017, 08:25 PM   #5
370zyzfr1
80 hp on e85? That's huge? I was thinking like 30-40
Old 01-29-2017, 11:04 PM   #6
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Benefits from the interchiller...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 01-29-2017, 11:05 PM   #7
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Quick question
18% OD
Headers
ID 850s
Rotofab
Fuel pump booster
You have enough fuel with the injectors and booster, you should see 40 to 50 rwhp increase...You just need to add a flex fuel sensor and tune...
Old 01-30-2017, 07:34 AM   #8
97ChameleonTA
97ChameleonTA's Avatar
Drives: 2013 ZL1 Convertible
Here are my gains after tuning for E85. The only additional mods from the 93 run was the supporting fuel system, everything else was the same.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15
FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's
New times to come with E85
2016 2SS Auto - Hyper Blue Metallic
Roto-Fab CAI
97ChameleonTA is offline   Reply With Quote
Old 01-30-2017, 07:52 AM   #9
crazydave
crazydave's Avatar
Interhiller was added later, e85 and dsx ff system was the only Change.
2013 ZL1 CRT M6
Old 01-30-2017, 05:52 PM   #10
RedZL1
Drives: Victory Red ZL1
Impressive gains!
RedZL1 is offline   Reply With Quote
Old 01-30-2017, 11:19 PM   #11
370zyzfr1
So one can pull nearly 700whp without cracking open the engine and putting in new rods etc? I think I would rather go this route instead of a cam if I can get those gains. I would be happy with 50hp more.
Old 01-31-2017, 06:40 AM   #12
crazydave
crazydave's Avatar
It's about the same cost as a cam swap. I only have 2 regrets; that I didn't go with ID1300s from the get go and that I didn't add a touch more boost like 97chameleonTA's pulley combo.
Otherwise it's been great. 93 when I want gas milage and e85 when I want power.
2013 ZL1 CRT M6
Old 01-31-2017, 09:10 AM   #13
370zyzfr1
Yah I would rather. It open up the engine for roughly the same gains. That's the last thing I wand to do.
Old 01-31-2017, 11:59 AM   #14
jscott
Drives: 2010 2SS RS M6 npp e-force
Where are you guys getting your flex fuel sensors? Did you use a kit?
jscott is offline   Reply With Quote
