06-29-2013, 10:17 AM | #1 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
detailing noob questions
I go the dawn, speedy prep towel, detail spray, porter cable and Adam's 2 step correction and polish. I'm ready to do this. Then questions pop up.
1. I'm going to mask off my vinyl but what about the paint in between the rally stripes, how am I going to get in there with the machine. 2. Same question for awkward areas like the bumper area where the headlights are. There will be more as I do this. I'm a painting correcting virgin. My paint is not bad at all. Garage kept daily driver. Doing this to keep her shining bright. Please enlighten me Oh Gurus of Gleam. I'll be back. I'm 1/4 through the Speedy Prep process this morning. I'll need answers in a few. Last edited by bandier; 06-29-2013 at 10:17 AM. Reason: correction |
06-29-2013, 10:41 AM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
1) If you are new at this, you don't. Get a full correction or two under your belt and then you can try taping up the vinyl around that paint and going at it, but if you're totally new at it I would personally advise going after that paint with a buffer.
If you feel confident, mask off the surrounding vinyl about 4 to 5 inches in on both sides and then buff the paint in between. 2) If you don't have a small buffer like the 3 " GG or a rotary with an extension, you only have two options: a) Don't do it b) Do it by hand.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
06-29-2013, 10:51 AM | #3 |
Got mine!
That's what I need to know. Cool thanks.
06-29-2013, 10:53 AM | #4 |
I like teeth.
good luck and remember the speedy towel should only take you about 20 to 30 minutes max
06-29-2013, 12:02 PM | #5 |
Got mine!
06-29-2013, 01:24 PM | #6 | |
I like teeth.
Do one more section and feel it after with a plastic baggie. If it still feels rough, continue to clay until it doesn't. Once you know how to get the section to pass the baggie test, it should be rinse and repeat. It still shouldn't take longer than 30 minutes though.
06-29-2013, 01:28 PM | #7 |
Got mine!
k... thx for the help! It always takes longer when doing something for the first time. Hmmm, well for most things. ; )
06-29-2013, 01:33 PM | #8 |
I like teeth.
agreed. hopefully next time you do it will be much quicker
