12-08-2011, 02:13 PM | #1 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Anyone running a Meziere Electric Water Pump?
Decided I am going to run a Meziere EWP on my quest for a ~530 rwhp NA H/C build. They were good for about 8rwhp on an ls1 car. Worth 600 bucks?...I doubt it...but they look good and keep the motor running cooler.
I am getting conflicting information depending on where I try and order this part. Some websites say you need nothing extra (on mezieres website they say everything included). Others say you need an old school small block chevy thermostat. Some say you need an entirely different thermostat housing. And yet others say you need a 160 thermo. No sure what all I need for the install. Does anyone know? Maybe depending on who sells them they come with different parts for the install? thanks, Troy |
12-08-2011, 04:09 PM | #2 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
Your stock thermostat and housing is fine, though this is a good time to do a 160* thermostat.
I am happy with this mod at my power levels. It is good for drag racing and daily driving. It would not be good for road racing where you spend a lot of time near redline. When I drag race, I am able to "hot lap" the car easily, starting each race at 180* and cooling back down to 180* by the time I drive back to the staging lanes. I can also turn on the pump while the engine is off but the ignition is on. That also helps during cool down times. You should notice an improvement in MPG as well. With an underdrive pulley, expect 10-12rwhp. Padre |
12-08-2011, 07:23 PM | #3 | |
12-08-2011, 08:18 PM | #4 | |
Padre |
12-08-2011, 11:15 PM | #5 | |
I emailed meziere and they said the only other thing I will need is a relay. They sell a kit with this relay and some wiring. Do u know anything about this? Thanks again |
12-09-2011, 09:06 AM | #6 | |
I suck at wiring, but I'm sure I could have done a relay with instructions with Meziere. I could not have done what John did - that took more knowledge than simply instructions. But it can be done. Padre |
04-04-2012, 01:25 PM | #7 | |
Drives: 2010 CAMARO SS Join Date: Apr 2010
04-04-2012, 07:40 PM | #8 |
Drives: cts-v Join Date: Dec 2011
As stated it will come with everything you need except a relay. Tensioner spacer, gaskets, spacers, bolts, heater hose fittings. Use your stock t-stat or upgrade, stock housing or upgrade, and factory upper and lower hoses. If you wire to a selectable switch I highly recommend some sort of idiot light that is illuminated when the pump is off so you don't forget about it.
04-04-2012, 08:39 PM | #9 |
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Nov 2010
GM High- Tech Performance just did an install of the Meziere ewp and ATI underdriven damper on a cammed 2010 ls3 and picked up almost 18 rwhp and a little over 17 lb-ft! Not bad for mods that won't hurt drivability and don't require a tune. Find it in the April 2012 issue
04-05-2012, 11:52 PM | #10 |
Drives: Camaro 2SS Join Date: Jan 2010
Has any magnacharger owners put an EWP on their set up?
04-06-2012, 09:42 AM | #11 |
04-06-2012, 10:14 AM | #12 |
04-06-2012, 10:45 AM | #13 |
Actually just found one on Blu808.com for the 2010+ Camaro at only $675!
04-06-2012, 01:42 PM | #14 | |
The part number for the 2010+ camaro EWP is wp329. On the blu808 website it says part number 396...which may just be a generic number for their website...but just make sure. In the product description it talks about wp319 as well...which is the part number for an ls1 car. |
Similar Threads | ||||
Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 125 | 02-05-2024 09:55 PM |
Fuel pump running when car is off | SILVER79 | 5th Gen Camaro SS LS LT General Discussions | 5 | 06-28-2011 10:52 PM |
Water pump? | RickyTheStorm | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 21 | 04-27-2010 01:47 PM |
PERRIN Performance Water/Methanol Injection Kit | PERRIN_JOHN | Forced Induction | 4 | 03-17-2010 09:57 PM |
Mr Clean Auto Dry & waterblade? | Matt'sSS | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 08-17-2009 12:19 PM |
