12-06-2016, 07:21 PM | #1 |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
GM Reveals 2018 Opel/Vauxhall Insignia Grand Sport/Holden NG Commodore
VAUXHALL REVEALS ALL-NEW INSIGNIA
General Motors December 6, 2016
Luton – Vauxhall has released first pictures of the all-new Insignia, known as the Insignia Grand Sport, which will receive its world premiere at the 2017 Geneva Motor Show in March. Following on from the previous generation, which won the European Car of the Year in 2009, and sold over 30,000 in the UK last year, the Insignia Grand Sport is based on a completely new vehicle architecture. Its revised proportions result in a more spacious interior, giving the car a more athletic appearance and an improved road stance, including class-leading aerodynamics and Cd figure of just 0.26. Like with the Astra, efficiency was key for the engineers. Optimised packaging and the use of lightweight materials have helped cut the weight by up to 175kg, allowing high-tech features such as the ultra-modern all-wheel-drive system with torque vectoring and the new eight-speed automatic transmission to exploit their strengths to the full. There is a raft of top technologies that make driving the Insignia Grand Sport safer, more relaxing and more comfortable than before. Next generation IntelliLux LED matrix lighting, Lane Keep Assist, Head-up Display and unique AGR-certified premium seats, front- and rear-seat heating and a heated windshield are just some examples. Outstanding infotainment and connectivity are also on board thanks to the latest generation IntelliLink systems and Vauxhall OnStar, which with the launch of the Insignia Grand Sport, will offer even more functionality for customers. It is also the first Vauxhall with an active aluminium bonnet, improving pedestrian protection considerably. “Vauxhall is raising its game even further with the launch of the new Insignia Grand Sport,” said Rory Harvey, Vauxhall’s Chairman and Managing Director. ““It has all of the virtues of its successful smaller brother the Astra, and takes those to a higher level. The Insignia Grand Sport will set new standards for design, efficiency, technology and connectivity when it debuts next year at the Geneva Motor Show.” DESIGN The Monza Concept was the inspiration behind the interior and exterior design. Despite a largely unchanged length compared to its predecessor, the new generation car has managed to shed around 60kg of weight from its body-in-white alone. In total, the new car weighs up to 175kg less than the outgoing model. Its roof is 29mm lower and its track has increased by 11mm. The overhangs have been reduced considerably and the wheelbase enlarged by 92mm. The prominent grille and the slim-line headlamps enhance the wide horizontal design of the front end and provide it with a bold appearance. The grille sits lower than on the outgoing model and further emphasises its solid stance. What Vauxhall calls a “sweepspear” feature starts in the front door and gives the impression that the Insignia Grand Sport is always ready to pounce, which is another nod to the athletic lightness of the Monza Concept. The side window graphics feature an upper chrome strip, rather than a full-chrome treatment, and the coupé-like roofline graphically pulls the car down and emphasises its stretched appearance. The “blade” light catcher in the lower doors pulls attention rearwards. Clear and simple lines at the rear combined with the double-wing LED signature also give the car a wider appearance. The newly-designed high-mounted LED stop lamp has been integrated into the roofline. It helps to give the rear end of the Insignia Grand Sport a more high-tech look that is often found on premium brands. A further advantage of this sporty body design is that the newcomer has an exemplary drag factor of 0.26 making it one of the most aerodynamic vehicles in its class. “In its proportions as well as in each detail, we wanted the new Insignia Grand Sport to deliver an upscale quality feel,” said Brit Mark Adams, Vauxhall/Opel Vice President Design Europe. “Its design combines flowing lines and subtle surfaces with crisp, precise lines to exaggerate its dramatic proportions: it looks longer, lower and wider than it actually is, and it definitely looks upscale. Every design feature conveys technical know-how and the utmost precision. The new Insignia Grand Sport is an excellent value proposition with the aura of a car from the premium, upper class.” The attention to the smallest detail is also tangible inside the vehicle. Clean lines, pleasant surfaces and first-class craftsmanship also provide a feeling of elegance and lightness. The cockpit is fully aligned to the driver who sits 3cm lower than previously. In addition, the driver is integrated better and gets a completely new driving experience. The centre console provides additional support, the instruments face the driver and all controls can easily be reached. All this results in a position similar to the one provided in a competition touring car. The frameless touchscreen of the IntelliLink infotainment system exudes a sophisticated and technical charm. Furthermore, the system is much more intuitive to use than before. Apart from the driver, all other occupants of the Grand Sport also benefit from the new design and the reworked proportions of the car. The extended wheelbase gives passengers in the rear more space. PROPULSION TECHNOLOGY The Insignia Grand Sport will be available with a wide range of turbocharged engines and transmissions when it is officially launched next year. The highly efficient eight-speed automatic transmission is new to the line-up. It impresses with class-leading shift quality. The gear ratios have been extended and shifts are extremely smooth and hardly noticeable. Simultaneously the car accelerates eagerly – even at low engine speeds. The eight-speed automatic transmission, which will initially only be available in combination with all-wheel drive, is friction-optimised and improves efficiency. New intelligent all-wheel drive Two electrically controlled multi-plate clutches replace the rear axle differential. For the first time, it will provide an all-wheel drive Vauxhall with torque vectoring – the best way to transmit power to the road, even if it is wet, icy or snowy. The vehicle receives steering impulses via the active, controlled torque distribution to the individual wheel. For example, when cornering, additional torque is transmitted to the outside rear wheel, enabling the Insignia Grand Sport to corner more precisely. The system reacts within a split-second when the accelerator is pressed, keeping the car more stable and easier to control in every situation. The further improved FlexRide chassis provides the basis for optimal, situation-based driving behaviour. It adapts the dampers, steering, throttle response and shift points (on automatics) independently or based on the modes ‘Standard’, ‘Sport’ or ‘Tour’, which can be selected by the driver. Depending on the selected mode, steering and throttle response are more direct and the ESP anti-skid system intervenes earlier or later. The new central ‘Drive Mode Control’ software is the heart and soul of the adaptive chassis. It continuously analyses the information provided by the sensors and settings and recognises the individual driving style. DRIVING ASSISTANCE SYSTEMS No other model in the segment offers such a wide range of intelligent technologies as the new edition of the Vauxhall flagship. One of the highlights is the next generation of Vauxhall’s innovative and award-winning IntelliLux LED matrix light. It now has 32 LED segments – twice as many as in the Astra – that are all integrated in the new slimmer headlamps of the Insignia. The increased number of LED elements enables the various light patterns to adapt to the prevailing traffic situation even more precisely and the transitions between the modes are more seamless. This results in an improvement of both the quality of light distribution and light intensity. To improve visibility even further while driving through curves on full high beam, the engineers added a new function to the new Insignia’s IntelliLux LED matrix headlights. The light intensity at the inner matrix segments rises according to steering angle in order to increase the illumination of the curve. In addition, a further high-beam spotlight provides additional illumination at full high-beam for up to 400 meters. Additional driver assistance systems include:
Vauxhall is still one of the few manufacturers to offer seats certified by “Aktion Gesunder Rücken” (Campaign for Healthy Backs). The premium ergonomic seats in the Insignia offer a unique combination of side bolster settings, massage, memory and ventilation functions in addition to the standard setting possibilities. Passenger in the rear can also look forward to more comfort with the two outside seats being available with optional seat heating. Elsewhere, the heated windscreen guarantees good visibility quickly on cold winter days. In addition, keyless “Open & Start” comes as standard on all trim levels and enables comfortable access to the vehicle. Great entertainment and outstanding connectivity, both typical for Vauxhall, are provided by the latest Apple CarPlay and Android Auto compatible IntelliLink systems. And while the smartphone is seamlessly integrated into the vehicle’s infotainment it can also be charged wirelessly without the use of a cable. The ground-breaking connectivity and service assistant Vauxhall OnStar is also on board, offering services ranging from Automatic Crash Response to Stolen Vehicle Assistance. A new concierge service will be launched together with the Insignia Grand Sport, enabling its occupants to ask OnStar advisors to select a hotel and proceed to room reservation. Furthermore, up to seven devices can be connected to the Wi-Fi Hotspot. Photography
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) Last edited by FenwickHockey65; 12-06-2016 at 07:38 PM. |
12-06-2016, 07:32 PM | #2 |
Next-Generation Holden Commodore Breaks Cover – Brings Premium Technology To The People
General Motors December 7, 2016
Holden has today revealed first images and more details of the all-new Commodore ahead of its Australian launch early in 2018. The next-gen Commodore takes cutting-edge safety, driving and infotainment technology and makes it available for today’s Australians, everywhere. The next-generation Holden Commodore is democratizing technology. Now with images of the next Commodore breaking cover, Australia gets its first look at the sleek and sophisticated design that will be hitting Australian roads in 2018. Designed in Germany by the Opel team with input from GM Holden’s team, the new Commodore takes the best of Europe and makes it great for Australia. Building on information released last month regarding the next-generation Commodore, Holden has today confirmed a raft of premium technologies will make Commodore the most technologically-advanced Holden ever. From potentially life-saving safety technology features, to active driving technology and seamless infotainment, the all-new Commodore will make driving safer, easier, more involving and more connected than ever before for Australian customers. “Customers are expecting more of their vehicles than ever before,” said Holden’s Executive Director of Sales, Peter Keley. “The all-new 2018 Commodore redefines the level of technology people can expect, and how tech can help our customers be safer, more involved and more connected than ever before. The Commodore combines technology across a number of areas in a way that you would usually only find in high-end prestige vehicles and makes it available for everyday Australians. Combined with the howling V6, world-first all-wheel-drive system and all the on-road performance you expect from the Commodore, this is a car that ticks all the boxes and more,” said Mr Keley. Going on sale in Australia early in 2018, the new Commodore range will be headlined by the V6 flagship model, the first ever imported Commodore will honour the iconic nameplate by being the most technologically-advanced Holden ever. With a cutting-edge all-wheel-drive system channeling 230 kilowatts and 370 Newton metres to the road, combined with adaptive suspension technology, a company-first nine-speed automatic transmission and torque-vectoring all-wheel drive, the next-generation Commodore will continue to cement Holden’s reputation for class-leading driving dynamics and on-road refinement. Jeremy Tassone, Holden’s Engineering Group Manager for Vehicle Development, said the technical underpinnings of the next Commodore also represents Holden’s commitment to bringing the best vehicles from around the word to Australian customers. “From its cutting-edge all-wheel-drive system, to nine-speed transmission and adaptive suspension, this is a true driver’s car in the way Commodore has always been. We’re taking the best of Europe and making it even better for our Australian customers. I can’t wait for our customers to get behind the wheel” In addition to the Commodore’s unique all-wheel-drive system, further details surrounding the ‘FlexRide’ suspension system have also been confirmed. The continuously adaptable FlexRide chassis electro-hydraulically adapts the dampers to the road and the driving conditions 500 times per second or 30,000 times per minutes. Additionally, the driver can save personal preferences for the steering characteristics, throttle response and dampers via the ‘Sport’ button.
Exterior Design: The design of the next Commodore is based on the ‘Monza’ Concept car, created by the Opel Design team in Germany. The prominent front grille and the slim-line headlamps are directly inspired by the Monza Concept enhance the wide horizontal gesture of the front end and provide it with a bold appearance. The grille sits lower than on the outgoing model and further emphasises the solid stance. The side window graphics feature with an upper chrome strip, rather than a full-chrome treatment, and the coupé-like roofline graphically pull the car down and emphasize its stretched appearance. The ‘blade’ light catcher in the lower doors pulls attention rearwards. The new Commodore is as sleek as it looks: it has an exemplary drag factor of 0.26 making it one of the most aerodynamic vehicles in its class. At the rear, clear and simple lines combined with the slim, precise double-wing LED signature also give the car a wider appearance. The newly designed center high-mounted LED stop lamp has been integrated into the roofline. It helps to give the rear end a more high-tech look typical of premium brands’ vehicles. Interior Design: The attention to the smallest detail is also evident inside the Commodore. The cockpit is organized along horizontal lines, enhancing the feeling of elegant lightness and of space. The cockpit is orientated to the driver for a sportier feeling. The generous center console that further embraces the driver provides the feeling of sitting in a much larger class of vehicle. Clean lines, modern surfaces and first-class craftsmanship with soft-feel materials at all touch points contribute to a feeling of elegance and grace. Infotainment system design: Equal attention has been paid to the controls and the infotainment interface. The frameless touchscreen of the infotainment system exudes a sophisticated and technical charm. Many functions are controlled via the touchscreen in order to simplify the interface, while three clusters of buttons have been designed to allow quick and intuitive operations: the upper ones for the major functions of the infotainment system, the central ones for climate and heating controls, the lower ones for driver assistant controls. This very clear set-up avoids drivers and passengers having to dive into sub-menus on the touchscreen to find the most essential functions. NEXT-GENERATION COMMODORE KEY HIGHLIGHTS:
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) Last edited by FenwickHockey65; 12-07-2016 at 05:43 PM. |
12-07-2016, 01:17 AM | #3 |
Looks great! Can't wait to see what the Regal GS AWD will be, if/when they make it. Might have to pick one up in a few years...
12-07-2016, 08:13 AM | #4 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I like it!!!
12-07-2016, 09:49 AM | #5 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Looking good.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-07-2016, 10:35 AM | #6 |
Drives: 21 Bronco Join Date: Jun 2012
Thats a damn fine looking vehicle
12-07-2016, 01:07 PM | #7 |
Moderator.ca
I don't think I will ever be able to look at the interior of a RHD car and not have my brain scream 'the steering wheel is on the WRONG side!'
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
12-07-2016, 01:46 PM | #8 |
Iron fist, lead foot
Drives: 2003 Mustang Cobra Join Date: Jul 2013
That is a pretty good looking Opel.
Not sure I agree with the use of the Commodore nameplate. At least on the blue oval side of things they didn't just slap the Falcon name on a Mondeo and call it good.
'03 SVT Cobra-SC4.6L V8 || modded with mods'n'stuff
12-07-2016, 04:18 PM | #9 | |
The more I see this though, the more I like it. I actually like the new gear selected stick Buick is using too. |
12-07-2016, 05:44 PM | #10 |
Holden press release is up. Much more performance details in that one.
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
12-07-2016, 07:08 PM | #11 |
12-07-2016, 08:04 PM | #12 |
Soon I'd guess, unless Buick wants to wait for NAIAS next month.
12-08-2016, 12:14 AM | #13 |
12-08-2016, 10:47 AM | #14 | |
For awhile there was a single Lincoln model that wasn't a rebadged ford. |
