Old 06-15-2010, 06:21 PM   #1
caperss
Drives: 2010 camaro 2SS/RS red white stripe
Exhaust Banging on floor under trunk
Does anyone else have that annoying banging on the floor (right rear) when hitting a bump? I've looked under the car and pulled on the exhaust but I dont see anything obvious. However when I hit a good sharp bump it sounds like the right rear muffler is hitting the trunk floor. Anyone else have this? Thanks Caperss
caperss is offline   Reply With Quote
Old 06-15-2010, 06:24 PM   #2
floraneg
Drives: 2010 1SS RS
That is funny. I started to notice the same thing yesterday. It seems to be getting worse. I haven't had a chance to get under the car, but it does feel as something is wrong!
floraneg is offline   Reply With Quote
Old 06-15-2010, 06:37 PM   #3
TripleB
SoCal Mayhem
TripleB's Avatar
aftermarket?
cause i put an aftermarket on mine and it was rattling on the tunnel brace underneath. i took it back and they tightened up on the tunnel brace. it stopped. then the other day it started again. :(
i posted on here and others said to use washers and it'll stop, or upgrade the tunnel brace.
Old 06-15-2010, 06:47 PM   #4
floraneg
Drives: 2010 1SS RS
Mine is stock, no aftermarket parts to cause it.
Old 06-15-2010, 07:25 PM   #5
|BLACKSS|
|BLACKSS|'s Avatar
Drives: BLACK 1SS
i would like to know to i have resonator w/x pipe and muffler delete and i have a rattle noise on sharp bumps (driving me nuts)
|BLACKSS| is offline   Reply With Quote
Old 06-15-2010, 08:04 PM   #6
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
My car is new and does this. I haven't taken it back to the dealer to adjust because I am replacing the entire exhaust with Doug Thorley shorties, Magnaflow cats, and Borla Touring cat-back.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 06-15-2010, 08:59 PM   #7
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
Hitting the tunnel brace. BTDT. Need to loosen all the clamps and jack the exhaust really high and retorque the clamps. It will settle down some but you have to have clearance above the tunnel brace. I bought an Elite Engineering tunnel brace to give me more clearance.
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 06-15-2010, 09:11 PM   #8
naga
Always be positive!!!
naga's Avatar
Drives: IMB 1ss/ MT
I had the same problem in my rear right exhaust... when i reach a certain RPM (1800) i get a vibration/rattling noise... I took it to the dealer and explain it to my service manager and told him to send someone with me for a test drive.. As soon as the guy heard it he said he can fix it, if they can’t they will replace my right exhaust… now I’m running on a brand new rear exhaust... ever since I have never had a problem….
I would recommend that if anyone one wants to explain anything to a service manager plss take them for a test drive and show them the actual problem…
naga is offline   Reply With Quote
Old 06-16-2010, 12:00 AM   #9
JS
JS's Avatar
Drives: 2010 Camaro SS
YEPPERS, my edelbrock x and magna comp axleback it rattling
I am going to tweek it this week, did a customers car and its rattling too..
They cant make anything right nowadays...
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 06-16-2010, 01:15 AM   #10
TripleB
SoCal Mayhem
TripleB's Avatar
A friend told me the output driveshaft bolts might be loose too..worth checking that out as well, just in case.
Old 06-16-2010, 04:56 AM   #11
Slowhawk
Drives: 1999 Trans Am
Alot of times it's the crossbrace.It will sound like the back of the car. These cars flex a ton over bumps. I've tossed the brace a few times.
Slowhawk is offline   Reply With Quote
Old 06-16-2010, 12:02 PM   #12
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
I have some noise too. I have an MBRP set. They include their own tunnel bracket that hangs down a bit lower. When I installed my exhaust I had about 7/8" space. Two weeks later it was down to 1/4 - 3/8. I know it is less now, but not touching. Over bumps I bet it is flexing enough to make some noise. I will have to tweek it again too one of these fine days.
HeavyD is offline   Reply With Quote
Old 06-16-2010, 01:41 PM   #13
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
My corsa rattles on my tunnel brace as well, only started a month ago. It will vibrate and knock on the brace at 1100rpm in 6th gear.
Bentley78 is offline   Reply With Quote
Old 06-16-2010, 04:23 PM   #14
caperss
WOW I guess this is a problem after all. My system is bone stock and now that I think about it, it only happens under certain types of bumps/situations and it would be at the times the car would be definately flexing and very well may be the tunnel brace(not loose but a clearence problem). I havent been under the car but would washers between the brace and the underbody help give more room between the pipes and the brace? would this lower the tunnel/brace to give more room? just a thought.
New low profile electric exhaust cutouts for your Camaro @ PFYC.com Redshift V8 Bolt-Ons & Tunes 8 08-14-2014 04:19 PM
axle back vs catback exhaust kozzmo49 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 03-28-2012 09:27 AM
2010 Camaro Complete Exhaust System Special X-treme Horsepower V8 Bolt-Ons & Tunes 25 07-29-2010 04:22 PM
SOLO Performance Camaro Exhaust Sound Clips Compilation GOINGSOLO2 V8 Bolt-Ons & Tunes 29 04-11-2010 08:11 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 06:39 AM
