Old 10-06-2011, 11:01 AM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
INTERCOOLER DRAG TANK NOW AVAILABLE!!!!
Exclusively from Torq is this all new 2010+ Camaro Supercharger Intercooler Tank. We have been working with an industry leading manufacturer to come up with a great looking and functional intercooler tank to reduce IAT's and add some style to your engine bay.
The larger volume of fluid that this tank holds helps to keep intake air temperatures lower. At the track this tank really shows it's benefits as you can pack it with ice and water in between runs to chill the intercooler system which yields you faster times.
Aluminum supercharger tank designed to replace the plastic supercharger tank used in 2010-2011 Supercharged Camaro's. It features billet aluminum hose connections and a fuel cell style cap to make packing the tank with ice a breeze.
They are built from strong .100 in. aluminum that can be polished or powder coatred for a custom look.
Torq's expansion tanks provide increased strength and a more reliable performance than stock plastic to prevent fluids from leaking onto the ground and being lost out of your cooling system completely.
This tank is a direct replacement for Whipple Supercharged Camaro's. If you own a Magnacharger or Kenne Bell, please select the optional installation bracket.
Offered in 2 different finishes. Bare Aluminum & Black Powdercoat.
You will notice that this tank has a relief valve, which comes in 15psi or 25psi and we also offer it in full "drag" style WITHOUT any relief valve but the cap WILL LEAK without the pressure relief
PM me for more information
Meister@Torq is offline   Reply With Quote
Old 10-06-2011, 11:09 AM   #2
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Looks great how is the intercooler with the dual fans coming for the maggie????
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-06-2011, 11:14 AM   #3
Meister@Torq
We are testing the 2nd revision next week. This tank will be one of the best modifications you can do hands down.
Old 10-06-2011, 11:17 AM   #4
Gotthat02fire
Cool can't wait ordering soon!!!!! Lets us know how things go with the intercooler can't wait to see what it can do for IAT's!!!!
Old 10-06-2011, 11:28 AM   #5
Meister@Torq
Wicked. Trust me, jamming this thing full of ice will reduce IAT's drastically
Old 10-06-2011, 11:45 AM   #6
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
So does the original maggie cooler run just water? So i take the one that came with maggie off and run lines to this one? Do you have to run ice? Where does the water go when ice melts? Can you drain to refill with ice to prevent overflow?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-06-2011, 11:46 AM   #7
jsharp
jsharp's Avatar
How much?
Old 10-06-2011, 12:14 PM   #8
Meister@Torq
This is a 100% replacement of your maggie, whipple or KB unit. The KB and Maggie unit's will come with a new hose kit as an option. The bottom of the tank has a drain on it so you can drain the ice/water and fill it with 50/50 for the street.
For the track, running ice water will prevent cooling below ambient.
Old 10-06-2011, 12:15 PM   #9
Meister@Torq
How much?
PM sent
Old 10-06-2011, 01:10 PM   #10
Jessika
Drives: Anything Blown
Will it work in the G8
Jessika is offline   Reply With Quote
Old 10-06-2011, 01:26 PM   #11
Meister@Torq
Possibly...might take a bit of mounting changes
Old 10-06-2011, 01:48 PM   #12
MudderFinger
MudderFinger's Avatar
Drives: 2011 IOM SS/RS
I can not find this on the website, do you have a link?
MudderFinger is offline   Reply With Quote
Old 10-06-2011, 02:11 PM   #13
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
How much?
HufferSS is offline   Reply With Quote
Old 10-06-2011, 02:26 PM   #14
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
No E-force option? :(
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Supercharger Intercooler Tanks Available - REDUCE IAT's!!!!!! Meister@Torq Forced Induction 23 03-21-2012 07:00 PM
******* PROCHARGER HO Intercooler System Kit and Tuner Kit Special ******* DREV LSX Forced Induction 27 10-07-2011 07:19 AM
Unbeatble Prices on ACT / Fidanza / Hurst / Mishimoto / MTI / SLP / Spec / More maperformance Transmission / Driveline 18 10-26-2010 02:16 PM
[VIDEO] More drag race development at Rocky Mountain Raceway PfadtRacing Camaro Photos | Spyshots | Video | Media Gallery 5 08-25-2010 07:39 PM
Challenger Fest ! Only 20 spots for Camaros to Drag race nhra stocker Dragstrip and Launch Techniques Discussion 61 08-23-2010 06:30 PM
