07-28-2019, 11:01 AM | #1 |
Drives: 2018 ZL1 , 2020 GMC AT4 Carbon Pro Join Date: Apr 2019
Best spark plugs?
I'm having trouble finding info by searching. I have the LS3 and I'm getting reading order headers and a tuner from RDP. Since I'll be removing the plugs to remove the OEM headers, I figured I'd replace the plugs wince I assume they're the originals.
I'm assume I need the .040's but it seems most of the iridium plugs seem to be geared towards forced induction, or highly modified motors. My only other mods are CAI and axle back exhaust. I know it won't make a major difference, but I am just curious as to what you guys would advise I buy to replace the current ones? Thanks. |
07-28-2019, 11:05 AM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The factory Ac Delco plugs are Iridium. Factory works just fine until you start messing with engine work or add FI.
More to come. |
07-28-2019, 11:06 AM | #3 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
41-110 AC DELCO if the motor is stock
Bone Stock |
07-28-2019, 11:29 AM | #4 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
What about for a heads/cam car?
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
07-28-2019, 11:42 AM | #5 |
that depends on compression. Im on TR7IX. its 2 heat ranges colder than stock and normally for boosted applications since its better at resisting knock
i raised the SCR on my car with the milling of the heads. the idea is to go with the hottest plug and not have knock. i havent tried the TR6IX but when i take the car in for manifold, and E85 tuning, in gonna take a set of each and let them figure out which one works best Sent from my SM-G975U using Tapatalk
Bone Stock |
07-28-2019, 02:07 PM | #6 |
SomeguyK
TR6 is a popular plug for that.
More to come. Last edited by Black_SS10; 07-28-2019 at 02:55 PM. |
11-25-2019, 08:25 AM | #7 |
Do we have a thread with a sticky listing different plugs and gaps for different applications? Yeah, I realize that could end up being an infinite number of listings with so many parts/setups out there.
I've had my car for ten years last June with the S/C since for about 9 of those years. I'm at 32K miles and still on the original plugs and wires. After looking around this forum, I'm thinking of getting Taylor 409 wires in blue. Am thinking AC Delco or NGKs, but which versions, platinum or iridium? I keep seeing gap to 0.040, so I'm guessing that's stock. Saw dynodteve's recommendation of 0.032. Is that suitable for my setup? Thx.
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; MGW short shifter; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! 2014 CTS-V Sedan, Black/Black, Auto, Recaros, Ultra-view, Red Brembos. Stock |
11-25-2019, 12:06 PM | #8 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I use the Taylor 409s, they've been great. Even with 2 inch primary headers. Same set for 4 years now. In my opinion, I would move away from Iridium since you are FI and get a copper plug. At your power level, the #6 heat range plugs would probably be best. NGK TR6 are very popular. (part#4177) I moved to the ngk br7ef which is a non extended tip copper plug in the #7 heat range, but I dont like the idle/driving manors. Considering going back to the tr6.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-25-2019, 03:18 PM | #9 | |
