Old 01-26-2021, 06:42 PM   #1
layzurguy
Ride On!!!!
layzurguy's Avatar
Drives: 2012 SS Ragtop
Trim Removal
I'm Trying to figure out how to remove the panel that houses the Dome light, Homelink, sun visors, etc. I need to get to wiring that lights up the AirBag so i can install a Gen5DIY cable for my radar detector.
Any help would be appreciated.
Im not sure if i can just remove the dome light housing and get to it that way or not.
2012 SS Vert
layzurguy is offline   Reply With Quote
Old 01-26-2021, 07:17 PM   #2
Pearlj10
Drives: 2011 Camaro 2LT
I believe there’s 4 clips that hold it in but don’t quote me on that. I tried connecting my radar detector there, too, but really didn’t like the “probe” pins that were provided. Maybe the Gen5DIY connector is better (I’m guessing it is, I like his stuff), but I ended up just mounting the detector on the far left side of dash and running power to the fuse block there and using a big bolt near the fuse box as ground. Super solid connection. My main objective was minimizing the view blockage of detector on the non-vert model. I feel like it’s worth a small sacrifice in detector performance, although I’ve red accounts of people putting them on their passenger seat and they still work fine.
Pearlj10 is offline   Reply With Quote
Old 01-26-2021, 07:19 PM   #3
Pearlj10
From an older post:
look it the DIY section for headliner removal. I posted the how to there:
http://www.camaro5.com/forums/showthread.php?t=203826
that should get you what you want.
Looks like two screws and three clips.
Old 01-26-2021, 08:22 PM   #4
layzurguy
Ride On!!!!
layzurguy's Avatar
I need to take the whole panel down (I think) I'm not sure if the hard tops are the same. ill have to see if any of the instructions match up. thanks!
