11-29-2023, 12:51 PM | #1 |
Caliper Refresh
Been doing HPDE days for 20 years and I've never refreshed my calipers.
1. How much would one charge for a caliper refresh? 2. What's involved? Thanks for your input, ~ Sean
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
11-29-2023, 07:38 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Its relatively easy job just pull the calipers, use compressed air to pop the pistons then remove boots an seals, and then reverse the process. Rock Auto, Racing Brake, and Giro Disc have the seals an boots. It’s also a good time to get vented pistons if not already installed. Rock Auto for OEM pistons and Racing Brake for the scalloped style piston.
Orange Krush II
11-30-2023, 05:29 AM | #3 | |
Drives: 1LEs Join Date: May 2009
For the J6H (both regular and BCD size front calipers), you use the same dust seal PN but use 19207043 for the longer vented pistons, one kit per caliper. |
11-30-2023, 05:32 AM | #4 |
I've never done a caliper rebuild before but with the correct info, parts and tools I was able to rebuilt my fronts with vented pistons and high temp dust boots and they work so well I no longer run Ti shims.
Whether you do it yourself or have a shop do it, you definitely want the vented pistons. Some don't like the RB high temp boots because they are not to be exposed to brake fluid, but I didn't have any issues following the instructions and they are holding up great. If you're interested in more info let me know.
12-02-2023, 08:37 PM | #5 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I did a video when I rebuilt mine.
01-10-2024, 02:20 PM | #6 |
Please excuse the delay, but really good video!! It showed me i don't have the confidence to do it. I'll have a local shop refresh, if at all
01-10-2024, 02:33 PM | #7 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I replaced my OEM dust boots with the high temp ones and they've been great. The OEM ones were cooked after a few trackdays.
01-16-2024, 12:45 PM | #8 | |
aka BeastZL1
Thanks for the feedback and glad it helped you make a decision.
