Old 04-13-2015, 08:14 PM   #1
Hoosier1LE
Hoosier1LE's Avatar
Drives: 2013 2SS/RS/1LE
Tire life question
I have a 2013 1LE with the original Goodyear F1s. Just turned 15k miles. Measured the tread today and have 5/32+ on rear on close to 6/32 on front. Wife gets nervous because when I get on it in a corner it gets a little squirelly and nannies kick in. I told her that I have a little more life in tires. She thinks I should change now. I have a set in basement with only 500 miles from a member here. Can I push these tires a little further?? Thanks in advance for any opinions.
Hoosier1LE is offline   Reply With Quote
Old 04-13-2015, 08:33 PM   #2
brokencilence
brokencilence's Avatar
Drives: '14 1LE, Z28.R
they are only 8/32 new. You're still have over half tread on the back. I'm 4500 miles with 6/32 front and 4/32 rear.
Far beyond stock....
brokencilence is offline   Reply With Quote
Old 04-15-2015, 07:28 AM   #3
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
You're still fine in the dry. In the wet I would recommend taking it easy. These are not the best wet tires to begin with and get worse as the tread depth gets lower. Any tire needs tread depth to evacuate water. As tires get down to about 4/32nds hydroplaning performances starts to drop off very quickly.
Rudy@Tirerack is offline   Reply With Quote
Old 04-15-2015, 07:28 AM   #4
Rudy@Tirerack
Old 04-15-2015, 07:29 AM   #5
Rudy@Tirerack
Old 04-15-2015, 01:24 PM   #6
JimE
JimE's Avatar
I think you are still fine in the dry.
JimE is offline   Reply With Quote
