11-17-2013, 07:12 PM | #1 |
Drives: 2010 Aqua Blue Camaro 2SS/RS Join Date: May 2013
Questions for people with a cam
So ive been saving up for a cam the past month or 2, within 2-4 weeks ill have $2000. I plan on ordering the night fury cam package which is ~$1,100. My questions are:
1) How much did it cost for you to get the cam installed? Will 900$ be enough? 2) With the night fury cam do i need all the other stuff like gasket, oil pump and timing chain? Or could i just get the cam? 3) Any other cam recommendations?
11-17-2013, 07:22 PM | #2 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
If I were you I'd save til you get you a melling, a c5r timing chain and an Ls2 chain dampner. Then your good to go. Your going to need water pump and head gaskets.
11-17-2013, 07:28 PM | #3 |
~COTW 6/30/14~
Definitely do the chain and damper. Mine snapped and caused a lot of damage 30 days after my cam.
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS BUILD TIMING CHAIN FAILURE TRANSITION FROM STOCK TO CAM VID |
11-17-2013, 07:53 PM | #4 |
it has an option for a high pressure or high volume, which one should i get
11-17-2013, 08:09 PM | #5 | |
High volume.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
11-17-2013, 10:19 PM | #6 |
Drives: LSx Performance Specialist Join Date: Jul 2011
You will need the gaskets, either from us or your installer. The oil pump and chain are a nice upgrade. Oil pump we use is 10296.
Shawn |
11-18-2013, 04:36 PM | #7 |
Drives: 2011 Camaro SS Convertible Join Date: Aug 2012
How many miles on your car? Since you are in there you might want to go ahead and replace the oil pump, timing chain and dampener.
You will definitely need the water pump gaskets, front timing cover gasket and front crank shaft gasket. The way I see it is I'm in there; do I really want to have to take this stuff back off because of a leak? My answer? I'm replacing the gaskets and if higher mileage? The oil pump and chain. I did both when I installed my new heads and cam. Good luck!
[COLOR="Blue"]CAI Intake, Kooks 1 7/8" LT headers and full exhaust, Vmax Ported Throttle Body, TFS Gen X 255 heads, custom VVT cam by Pat Guerra, RX Catch Can, Pedderized suspension, ghosted side markers, Technostalgia tail lights, Big Worm spears, Forgestar f14 in gunmetal, Nitto Invo 275/315
455HP/422TQ. |
11-18-2013, 04:39 PM | #8 | |
V8 Lounge member #2
Oops thanks Mikey Sorry OP. Mike is. Correct
11-18-2013, 06:18 PM | #9 |
20,000 miles
