Old 12-14-2017, 06:09 AM   #1
Bullethead
Drives: 2010 Camaro SS 6M, 2002 Tahoe
Top Speed
I'm a new member and this is my first post. I purchased a 2010 SS 6M last April with 47K on it. It appears to be stock except for short tube headers. Everything I've read says it should top out around 155MPH when the limiter kicks in. All I can get out of it is 135MPH. Anyone have any idea why?
Bullethead is offline   Reply With Quote
Old 12-14-2017, 06:30 AM   #2
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
What gear are you in? You should be in 4th.
mrvenicess is offline   Reply With Quote
Old 12-14-2017, 07:18 AM   #3
Bullethead
I wondered if that may have been the problem. I'm new to this muscle car business. Thanks!
Old 12-14-2017, 08:08 AM   #4
vinman
The BBOMG fill-in husband
vinman's Avatar
Yeah, definitely can't do a top speed run in 6th, you need to wind out 3rd then 4th so it doesn't take a lot of distance
UPSTATE C5 MEMBER
Old 12-14-2017, 08:55 AM   #5
Bullethead
Next time I find myself with a blocker to clear the way I'll have to try it again. Glad to know it was just operator error and not something wrong with my car.
Old 12-14-2017, 09:31 AM   #6
SquawkVFR
Drives: 2010 Camaro
SquawkVFR is offline   Reply With Quote
Old 12-14-2017, 10:06 AM   #7
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
...anything else done to the car? and not to question you but your tires are speed rated?
may I suggest a custom tune? so much left on the table and top speed limiter, skip shift etc can be tuned out/turned off...makes life easier and dare say could pickup a couple of mpg along the way...
dynoSteve at RDP gets my vote, great SCT/tune package! good luck OP and be safe!
Old 12-14-2017, 12:54 PM   #8
Bullethead
Thanks for the advice frankwjr, but I'll have to wait on any modifications for now. All my extra cash is being sucked into the 66 F100 I bought last month. But that's another forum...
Old 12-14-2017, 03:52 PM   #9
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
While in Mexico, I hit 145 in 5th, then shifted to 6th and ran out of road, so I had to back off. I have 3.91 gears, so there probably wasn't much top end left in her...
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 12-14-2017, 04:07 PM   #10
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
You could hit 143 in 4th with stock size tires.
5th should take you to ~170, if you can push the air.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 12-14-2017, 06:51 PM   #11
Taylortoons
Fred, I don't know if my 3.91s will get me to 143 in 4th. I was over five grand in 5th at that speed on stock rims and tires.
Old 12-14-2017, 07:24 PM   #12
Spec
Drives: 2010 Camaro 1SS LS3
Maybe this will help you figure out your gear ratio:
http://www.camaro5.com/forums/showthread.php?t=95142
Rear End Gears 101
After seeing numerous threads about gears, I figured I would do a small write up. Hopefully when people search and find this, they find their answers. Maybe it is good enough to even become a sticky. If you feel anything is wrong or maybe I left something out, feel free to comment and I will add it accordingly.
What is a ring and pinion?
Simple answer: Your driveshaft spins a pinion. Your pinion in turn spins the vertically mounted ring gear. Your ring gear is directly bolted to your differential, which turns your halfshafts/axles.
Here is a quick illustration (please note that this is a solid axle system, not an independent rear suspension, like our cars have. I choose to use this picture, because I feel it is easier to grasp the concept of a ring and pinion through a solid axle)
Part number 8 is your ring and pinion. The part on the right is your pinion, the part on the left is the ring gear
What do the numbers "3.73" "4.10" "4.33" etc mean?
Simple answer: It is how many times your driveshaft turns for every time your wheel spins once. For example, with 4.33's, if your wheels spins once, your driveshaft will turn 4 1/3 times. A simple formula to figure out what gear ratio you have is to take the number of ring teeth there are and divide it by the number of pinion teeth there are.
Will I loose top speed if I do gears?
Simple answer: No! actually if anything you will gain top speed! A stock LS3 top speed in 6th gear, with factory gears is 269 mph! Your car will never see that kind of speed (well if yours does, my hats off to you!). Assuming your speed governer is removed, you will be limited by how much power you are making and aerodynamics. Putting a more aggressive gear ratio in will put you in a higher rpm, which means you will be putting more power to the ground, getting you to a higher mph.
What gear ratio is best for me?
Simple answer: Automatics: 3.73's Manuals: 4.10's
More in depth answer: It varies on your setup. The main factor (assuming that the car's goal is optimal 1/4 mile time) is that you want to be a few hundred rpms past your redline when crossing the traps in the 1/4 mile.
A quick run down, if you trap the following in the 1/4... then here's a general idea of what gear you should get (this is assuming you have a 6200 redline... if yours is different, then use the calculator found on the bottom of this post):
Manuals:
< 122 mph: 4.33's
122-129 mph: 4.10
129-142 mph: 3.73
142-153 mph: 3.45
Automatics:
< 106 mph: 4.33's
106-112 mph: 4.10
112-123 mph: 3.73
123-133 mph: 3.45
133-140 mph: 3.27
Now this is assuming you have the suspension and tires to effectively utilize the given gear ratio. Some people ask "Well can I put 4.10's in my L99/6L80E?" The quick answer: Yes... but it is going to be an interesting ride. GM isn't dumb and knew that this heavy car was going to need some help getting moving, and put a steep 4.027 for 1st gear in the automatics. Paired that 4.10's, it will be A VERY AGGRESSIVE 1st gear. If you have the suspension/tire to withstand it, it will be a very very aggressive launch.
That being said, putting a more aggressive ring and pinion allows you to get into your "powerband" faster. Your powerband is the "sweet spot," so to say, of your motor, where it makes the most useable power. The faster you get into it, the faster your car goes. On the other end of the spectrum, you can "run out of gear." This is when you go past your power gear (4th gear for our cars) and have to shift into overdrive. This does not offer an ideal 1/4 mile time
Can I install gears myself?
Yes, but I would highly recommend against it, unless you've had some practice. Setting up gears is very time consuming and takes a little experience to get it right. I would suggest having someone with you that has done a few, if you are attempting to do this yourself. It is very easy to mess something up, and gets very frustrating. And the results can be catastraphic.
If you do not have this knowledge/experience at your disposal, I would highly recommend getting the work done at a reputable shop.
Will I gain rwhp if I install a set of gears?
No. Actually if anything, you might lose a little bit of rwhp (a negligable amount) due to an increase in parasitic drivetrain loss. This is greatly offset, because you will be getting into your powerband faster. The "butt dyno" will think you gained a lot of power, because you will be climbing the rpms faster, but in reality, you will be at the same power level.
Are gears noisey?
Simple answer: Yes and No. It's kind of a trick question. Some gears will make noise... even when properly setup. However, a good indication that the gears are not setup properly is excessive noise. This is why it is highly recommended to have someone, who knows what they are doing, around. I'm not saying one can't have a "crash course" and get it right on their first try. But it is not worth the risk, in my opinion.
Should I do anything else when I'm doing the ring and pinion?
Simple answer: Yes! It is a great time to install a set of differential bushings, as the differential will already be out, and it's one of those "well while I'm in there" things. Differential bushings are fairly inexpensive and will save you time and money down the road.
I installed a set of gears, it lowered my ET, but my mph (trap speed) went down? What's wrong?!
Simple answer: Absolutely nothing! As mentioned before, you are not adding horsepower with a set of gears, you are just accelerating faster. So your car just doesn't make it up to 115 mph to finish the 1/4 mile now, it only has to get up to 112 mph (I'm just making up numbers here, they are not accurate). Generally speaking, the higher you go with a gear, the lower your ET will get, but it will also lower your trap speeds. This is assuming you are not running out of gear in the last part of the 1320.
Are 4.10's prone to breakage?
I feel this is a touchy subject. Some say yes, I say no. There have been a few failures. But what you don't read is how many people haven't broken their 4.10's. I hope no one hijacks this thread and turns it into a "are 4.10s weak?" thread, but in this thread, it will just be left as: "Do a search, and make your own decision"
If you feel I should add anything, or anything is incorrect, please say so, and I will adjust this post accordingly. I will end this with an old saying that I was once told:
"Don't fear the gear!"
A few numbers that people will ask....
Manual transmissions (LS3/TR6060)
3.45 gears:
Top speed in X gear:
1st: 51 mph
2nd: 74 mph
3rd: 107 mph
4th: 153 mph
5th: 182 mph
6th: 269 mph
RPM at XX mph in 6th gear:
60 mph: 1380 rpm
70 mph: 1610 rpm
80 mph: 1850 rpm
3.73 gears:
1st: 47 mph
2nd: 68 mph
3rd: 99 mph
4th: 142 mph
5th: 169 mph
6th: 249 mph
60 mph: 1500 rpm
70 mph: 1750 rpm
80 mph: 2000 rpm
4.10 gears:
1st: 43 mph
2nd: 62 mph
3rd: 90 mph
4th: 129 mph
5th: 154 mph
6th: 226 mph
60 mph: 1650 rpm
70 mph: 1925 rpm
80 mph: 2200 rpm
4.33 gears:
1st: 41 mph
2nd: 59 mph
3rd: 85 mph
4th: 122 mph
5th: 145 mph
6th: 214 mph
60 mph: 1733 rpm
70 mph: 2025 rpm
80 mph: 2325 rpm
Automatic transmissions (L99/6L80E)
3.27 gears:
1st: 40 mph
2nd: 68 mph
3rd: 106 mph
4th: 140 mph
5th: 190 mph
6th: 242 mph
60 mph: 1525 rpm
70 mph: 1800 rpm
80 mph: 2050 rpm
3.45 gears:
1st: 38 mph
2nd: 65 mph
3rd: 100 mph
4th: 133 mph
5th: 180 mph
6th: 230 mph
60 mph: 1625 rpm
70 mph: 1900 rpm
80 mph: 2125 rpm
3.73 gears:
1st: 35 mph
2nd: 60 mph
3rd: 90 mph
4th: 123 mph
5th: 166 mph
6th: 212 mph
60 mph: 1750 rpm
70 mph: 2033 rpm
80 mph: 2333 rpm
4.10 gears:
1st: 32 mph
2nd: 55 mph
3rd: 84 mph
4th: 112 mph
5th: 151 mph
6th: 193 mph
60 mph: 1933 rpm
70 mph: 2033 rpm
80 mph: 2566 rpm
4.33 gears:
1st: 30 mph
2nd: 52 mph
3rd: 80 mph
4th: 106 mph
5th: 143 mph
6th: 183 mph
60 mph: 2033 rpm
70 mph: 2366 rpm
80 mph: 2700 rpm
If you have a different redline or different than stock height tires, and feel like doing the calculations yourself. Or if you are bored and feel like playing with some numbers, I use this calculator:
http://f-body.org/gears/
The Gear Ratios for a TR6060 (manual) are:
1st: 3.01
2nd: 2.07
3rd: 1.43
4th: 1.00
5th: 0.84
6th: 0.57
R: 3.28
The Gear Ratios for a 6L80E (automatic) are:
1st: 4.027
2nd: 2.364
3rd: 1.532
4th: 1.152
5th: 0.852
6th: 0.667
R: 3.064
Spec is offline   Reply With Quote
Old 12-14-2017, 07:25 PM   #13
Spec
In Mexico, I hit 152 before I ran out of road, effortlessly. I'm wearing stock gears though... it sure wanted to keep going faster, with plenty of power.
Old 12-14-2017, 08:04 PM   #14
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
Its legal to go that fast in Mexico?
Rainbow1616 is offline   Reply With Quote
