02-23-2012, 08:08 PM | #1 |
Rev Limiter
At what RPM will the rev limiter kick in on a manual transmission?
02-23-2012, 08:14 PM | #2 |
Drives: 2016 2SS, 2011 RS (past) Join Date: Aug 2011
I know on an automatic it's around 4000. Probably about the same for the manual
Past: 2011 RS, 2013 ZL1 Current: 2016 2SS |
02-23-2012, 08:19 PM | #3 |
Drives: 10 SS 08 675 13 Stryker 10 S1000RR Join Date: Jan 2010
I think it's 6250.. but don't quote me
02-23-2012, 08:26 PM | #4 |
Drives: 2010 2SS - Supercharged Join Date: Apr 2010
I think it's a little higher, like 6600, i know when I added the extra boost to my car I had them pull the limiter back so I didn't over do it and now it's at 6400.
02-23-2012, 08:33 PM | #5 | |
knows 2 facts about ducks
The rev limiter is 6700 if I remember correctly. That's auto and manual. |
02-23-2012, 08:47 PM | #6 |
Isn't the rev limiter just a idle? Cause if so, my car won't let me go over about 4300. Sorry if I have the wrong idea about rev limiter
02-23-2012, 09:00 PM | #7 |
A rev limiter is an rpm where the engine loses power. It's programmed into the ECM as a fail safe to protect the engine.
02-23-2012, 09:05 PM | #8 |
Drives: 2012 Camaro SS 45th Anniversary Edi Join Date: Nov 2011
Always Park Next To Camaros.???? Why would you type that? Do you like door dings?
02-23-2012, 09:33 PM | #9 |
I'm saying park next to other camaros as to avoid door dings by other people who don't care.
02-23-2012, 09:43 PM | #10 |
Drives: 2010 Camaro 2SS/RS 1967firebird 632 Join Date: Jan 2012
If you do hit the rev limiter rember It can bend the push rods!! real easy.
02-23-2012, 09:48 PM | #11 |
That is not reassuring, on my bikes I can hit the rev limiters all day long and not do any damage. Why have a limiter if it's set too hi?
02-23-2012, 10:12 PM | #12 |
Autos in park or I believe Neutral will limit to 4K in drive it's as stated earlier here.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
02-23-2012, 10:13 PM | #13 | |
Drives: Really Slow Join Date: Apr 2010
pretty sure the l99 revs only to about 4k rpm, when parked.
02-24-2012, 11:29 AM | #14 |
Drives: 1981 Z28 // 2010 1SS LS3 Join Date: Aug 2011
Similar Threads | ||||
L99 suggested rev limiter and shift points | BossCitySS | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 07-24-2023 01:48 PM |
LT1 Rev Limiter Problem at Track | GRSCAMARO | 4th Generation Camaros | 9 | 04-25-2011 12:00 PM |
Is there a rev limiter parameter for when the brake is depressed (2010 Camaro)? | 2010 Bumblebee | Tuning / Diagnostics -- engine and transmission | 12 | 05-07-2010 11:39 AM |
REV Limiter Stinks. | attymf | 5th Gen Camaro SS LS LT General Discussions | 79 | 03-19-2010 09:20 PM |
rev limiter | oldfart1941 | 5th Gen Camaro SS LS LT General Discussions | 91 | 10-21-2009 09:20 AM |
