05-25-2013, 07:51 PM | #1 |
Drives: 2013 1le Join Date: Nov 2012
who has fastest 1/4 mile--1LE
Wondering what are some of the other members times are in 1/4 mile ?
all this high Dyno numbers but can they put the power to the pavement. Last edited by onebad1le; 05-25-2013 at 08:05 PM. |
05-25-2013, 09:03 PM | #2 |
TIMEs ?
Well i will go first my car ran a 12.8 at 113 with only a 2.0 60 ft
and shifting at 6200 rpm-- alot of room for improvement |
05-25-2013, 09:07 PM | #3 |
Do you even lift, bro?
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 |
05-25-2013, 09:17 PM | #4 |
Loves Camaros
Drives: Red '79 Z28, '21 Red Hot M6 ZL-1! Join Date: Sep 2012
I bet SSGT Sukxost does the best ET in the quarter!
Old and new, sharing space!
05-25-2013, 09:26 PM | #5 |
times ?
Well with 210 more HP he better
05-26-2013, 07:04 PM | #6 |
The fastest
WEll I quess I have the fastest 1LE in the country
05-26-2013, 07:07 PM | #7 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
Dontcha mean the quickest ?
05-26-2013, 07:33 PM | #8 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
You have a couple things going against this list. The first being the 1LE is a track (road race package) so I would bet a lot of the owners won't take them to a drag strip. You also need to list mods with this type of list.
Your 12.8 was modded. Did you ever run it stock?
05-26-2013, 08:13 PM | #9 |
Stock
I didn't run it stock , I wish I did
05-26-2013, 08:33 PM | #10 |
*Disclaimer:
The following note is BEFORE my cam and retune. At the time I was 577WHP and 585WTQ but I was having low RPM hesitation issues. Those were fixed with the cam install and retune. After only a few launches, (before cam and retune) I pulled an 11.6 @ 123...I short shifted 1st and hit redline in 2nd :( Car was capable of quite a bit more with more launch practice and hitting shifts properly. With even drag radials, EASILY 10.8 or less IMO. With current set up, practice and drag radials...who knows
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 Last edited by SUKXOST; 05-26-2013 at 09:11 PM. |
05-26-2013, 08:47 PM | #11 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Do it!!!!!!!!
05-26-2013, 09:09 PM | #12 | |
05-26-2013, 10:11 PM | #13 |
Heaitation
What caused your hesitation ?
05-26-2013, 10:23 PM | #14 |
my new tuner found what I FELT in the car between gears (obviously kills times @ the track)
He said something along the lines that the fuel was commanded too late so he shifted it earlier and it's definitely WAY better now.
Thread Tools | |
