04-06-2015, 02:38 PM | #1 |
Drives: 2011 2SS Join Date: Jun 2013
flex fuel sensor tables
I am looking for someone that has done the flex fuel sensor swap and can discuss some tables in there tune. I had my car tuned and there are some issues I found a nice write up on the g8 page on what to change but one point is hazy regarding the target afr. If you have done this sensor and are familiar with what it takes in HP pm me or comment here and I will get in touch with you. I think mine is 3/4 way correct but not complete and its causing a fuel table to screw up
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
04-06-2015, 10:48 PM | #2 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
I can help you. I started by copying a lot of that info from my 2012 Silverado that has FF, but I know the HPT site has ones you can use too.
Jack Bilger
04-06-2015, 10:56 PM | #3 |
Code:
%Alcohol 0.00 6.25 12.50 18.75 25.00 31.25 37.50 43.75 50.00 56.25 62.50 68.75 75.00 81.25 87.50 93.75 100.00 Stoich 14.678223 14.322266 13.965820 13.609863 13.252930 12.896973 12.541016 12.184082 11.828125 11.472168 11.115234 10.758789 10.402832 10.046875 9.689941 9.333984 8.978027
Jack Bilger
04-07-2015, 11:11 AM | #4 |
I got that table filled out. I ended up finding something on the g8 forum that I think will get things done. Just not sure about a couple of the tables I will try and post the info on here once I get it figured out
04-07-2015, 11:13 AM | #5 |
I think much of my info is coming from a HOLDEN example in HP that has the sensor. I am not sure about the flex fuel spark table, and if mine is okay or not
