09-11-2014, 03:07 PM | #1 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
Vmax TB Install?
So i installed my new throttle body today and when i went to turn it on i got a Service Stabilitrak CEL. does anyone have any experience with this issue or might know a possible solution? I've checked all my connections and plugs and there doesn't seem to be an issue with them.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
09-11-2014, 04:30 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
This very common (even to be expected if you didn't disconnect your battery during install). Simply unplugging the TB electrical connection nearly always triggers a CEL.
After a few miles it will clear itself unless there's a real issue. BTW- it is also normal for the Stabiltrak light to come on momentarily with each start-up. Some folks just don't notice it until they've done a mod. |
09-11-2014, 07:21 PM | #3 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
That's not true. Ive installed dozens and never disconnected the battery and never had an issue or a code.
09-11-2014, 08:11 PM | #4 | |
Drives: 2010 Camaro 2LT Victory Red Join Date: Feb 2011
code
i had the same problem. but my tb was defective. when they sent the new one the same thing happened but once i cleared the codes it went away.
iam in southern nh if you need a hand figuring it out... Quote:
09-11-2014, 08:27 PM | #5 |
603 Camaros
Tried the battery disconnect and it cleared the CEL drove 60 mi. tonight no CEL triggered after a few stops either so that post i read somewhere about possible reminant power was probably correct.
09-11-2014, 09:02 PM | #6 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
How do you like the TB? Does it work as advertised?
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
09-12-2014, 01:58 PM | #7 |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Ignore this mod. The effect is minimal with the LLT. Go for CAI or headers or the icolater. They are worth it.
Im not Gray any more !!
09-12-2014, 06:14 PM | #8 |
Drives: 2014 2SS M6 "CHRISTINE" Join Date: Mar 2014
Disagree with last post, this mod is AWESOME and I could not be happier.
Evil Bee, did you you have a torque wrench for the bolts? I mean the 4 bolts for the TB are like barley tightened down, forget the spec off top of head, but its like 1/8 turn after finger tight. Maybe you over torqued and it's leaking? Also how did the gasket look when you took the old one off? Hope it gets figured out. If you sent your core back I have my old stock TB in case you need to send your unit back and get another one shipped out. I could lend you the stock TB until you are set up. EDIT: Sorry saw yours is an LS.
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my kingfrom this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning |
09-12-2014, 08:25 PM | #9 |
603 Camaros
Lawl thx for the support it's all good now no issues and there's a significant difference maybe someone who has only driven their car a few hundred or thousand miles may not notice it but my cars at 71,000 miles and i do very much notice the throttle response difference. Like Muscle Car Lover said above i have the LS which has smaller gears so i'm not sure if the LT's with the higher torque gears will notice the difference as much but it is there. Next mods are the Iceolator and Headers w/Hi flows though so i'm excited for those and thetune i'll need before next march to pass inspection.
09-13-2014, 03:32 AM | #10 | |
Wind Rider
With the V8 it works very well, with the LLT (it is a waste of money) and you have my word on it !!
09-13-2014, 06:42 AM | #11 | |
603 Camaros
Good for you, to each his own opinion yours has been voiced, listened to and frankly your experience is probably not the only one but neither is muscle car lovers or mine on the opposite end of the spectrum. So you had a less then expected experience, this thread was initially a troubleshoot thread not one of those is it worth it threads. So let's let the dead horse in the room stay dead and not keep kicking it.
09-13-2014, 06:44 AM | #12 | |
603 Camaros
I just used a ratchet wrench there's no reason for anything more i get the feeling if i used a torque wrench with my **bulging muscles i'd break one of the bolts by accident. ** May not be an accurate representation of posters muscles they could be even bigger who knows.
09-13-2014, 10:52 AM | #13 |
Drives: Camaro and Sierra Join Date: Jul 2012
This was a bone stock LLT for base run and then added TB from Tampa Tuning and iceolater. What doesn't show up is that its much more smooth with throttle response. My wife doesn't know anything about cars and said it felt like it drove better when she pressed the gas (this was her cars Dyno)
09-13-2014, 12:42 PM | #14 |
KaBoom1701
TB is one of the best first simple mods one can buy for our 5th Gen V6 cars.
You have my word on it!
Mods:
