01-13-2015, 09:01 PM | #1 |
Drives: 1LS Join Date: Jul 2010
2014 LS randomly shut off
Hi everyone, been away for a bit, today I was driving into work, and my car just shut off on a turn into a parking lot. Now I know the first instinct would be the key recall, but I'm too short for that to be even a possibility, and 100% sure I didn't touch it. I recently relocated to North Texas were temperatures are in 30s in the morning, from Florida where the coldest it got was about 60s. So could it be something with the temperature? Do I have to add anything to my car that will cause it to not randomly shut off? Has anybody else had this happen to them? This happened in a parking lot, where the damage would have been minimal but I don't want this to happen to me when I'm on the highway and can't steer my car.
01-13-2015, 09:10 PM | #2 |
Make a visit to your local dealer and explain it to them !
01-14-2015, 08:55 AM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I bought my car in Florida over five years ago and there are lots of every version of Camaro here. Pretty sure that's not it.
Is the key still in the run position when you go to restart it?
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-14-2015, 10:03 AM | #4 |
Obsessed Much?
Drives: 2015 Silver 1SS/RS M6 Join Date: Aug 2009
I don't mean to sound condescending, but the 1LS is a manual transmission. Are you sure you weren't it too high a gear when making the turn? Maybe you were in 4th instead of 2nd?
2015 1SS RS M6
01-14-2015, 10:11 AM | #5 | |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
The temperature shouldn't have an affect. These things will start and run in extreme temps, high or low, as most any car with EFI or direct injection will do these days. REMEMBER If the car shuts off at high speed, leave the key in the "run" position and shift to neutral. Steering and braking are still possible, but there will be no power assist. The steering wheel might feel heavy to turn and the brakes hard to press, but they will still work. Do NOT turn the key to "off" "acc" or any lock position. If you experience sudden acceleration instead, or the accelerator gets stuck to the floor, shift to neutral. Experienced users can cut power to the engine, place the key back in "run" and steer/brake to a stop. |
01-14-2015, 10:34 AM | #6 |
Drives: 2018 1SS 1LE M6 Join Date: Jul 2013
I've had this happen to me before I'll be in second gear pulling into a spot and my car just shuts off. If it stalled u should feel it shake a little. But it just turns off for me... Weird
01-14-2015, 10:30 PM | #7 | ||
