Old 04-11-2013, 06:38 PM   #1
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
borla atak axle back swap?
Hi all.
I have a Borla Atak axle back exhaust. I love it and it sounds great. I would like my Camaro to be a bit more quite. I was wondering if anyone in the ny, tri state area would like to swap out there exhaust with mine.
Im not looking for stock cans just another axle back that is less aggressive than the atak.
thanks joey
chopss is offline   Reply With Quote
Old 04-11-2013, 09:13 PM   #2
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
if you add a magnaflow resonated x pipe it will quiet down the exhaust and still sound great
camaro4mybday is offline   Reply With Quote
Old 04-11-2013, 11:11 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
That'll work, or if you can swap out for a S-type, that would sound good too.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 04-14-2013, 03:48 PM   #4
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
I have the Borla S type, been going back and forth if I want to go louder or not..might be interested in meeting up at a shop and doing the switch, talk me into it!
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 04-18-2013, 03:02 PM   #5
ZuluKilla8
ZuluKilla8's Avatar
Still interested in this? I have the Borla S i would swap with you
