03-25-2011, 12:48 AM | #1 |
dark side has cookies
Drives: 2012 Mustang GT Join Date: Feb 2011
X Pipe and Magnaflow Axle back
Ok so i wanted a second oppinion on this from you guys... i got quoted 100 dollars for the magnaflow X Pipe and 610 for the magnaflow axleback muffler delete system not including labor does this sound about right? cause i thought i heard people getting it down here for around 300....
2011 Camaro 1SS ::stock:: -Traded in- 2013 Mustang GT Paxton 2200 SL Supercharger Recaro Seats -Current- |
03-25-2011, 01:18 AM | #2 |
Drives: 2010 Summit White 2LT/RS Join Date: Jan 2010
The vendors on here have your parts for cheaper. Here: http://www.phastekperformance.com/20...maro-16582.htm
http://marylandspeed.com/magnaflow-2...791-p-763.html Phastek and maryland speed both have good reviews from what I've seen. Both should be listed in the vendor's section if you have any questions. Hope this helps Edit: to answer your question, I haven't seen that kit for $300. Unless maybe what you saw was a private sale on used parts? IDK, either way, those links should save you about $100.
Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit.
-Elbert Hubbard |
03-25-2011, 01:43 AM | #3 |
Drives: 11 Camaro Vert 2SS/RS 6M Hurst Join Date: Feb 2011
I was able to get the 16582 on amazon for $368 shipped and the tru x-pipe for $81 shipped.
03-25-2011, 01:52 AM | #4 | |
Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
Seems like its to much...check ebay and like another member said look in the vendor section and see if someone can give it cheaper.
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
03-25-2011, 06:47 AM | #5 | |
There is a single seller on there that has it for $350
-Elbert Hubbard |
03-25-2011, 08:07 AM | #6 |
Drives: '69 SS Convertible Join Date: May 2009
Call JDP Motorsports (www.MagnaflowPlus.com). They are a vendor here and they've had the best prices on Magnaflow that I've seen. Don't go by their website, call them and tell them you're on Camaro5.
But to answer your question......the price on the axle-back is way to high. The x-pipe isn't too bad but you can get it cheaper. I got all mine done for around $350....parts and labor. http://www.camaro5.com/forums/showthread.php?t=64964
Build Journal |
03-25-2011, 09:56 AM | #7 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Way too much...use the links the others have posted. No point in spending too much for something when it's out there for less.
03-28-2011, 10:40 PM | #8 |
Sorry for the late response but thanks alot guys! This is going to save me some cash.
Similar Threads | ||||
WTB: Magnaflow 16581 street axle back 2.5" | harmonicator | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 2 | 12-02-2010 03:51 PM |
Which Axle back: Magnaflow Street or SLP Loudmouth II??? | harmonicator | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 08-17-2010 03:36 PM |
Magnaflow Delete, then Resonated X Pipe, then X Pipe (with video) | Bumble_Bee | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 08-05-2010 03:53 PM |
MagnaFlow Axle Back w/ Mufflers - Install and Review (now with drone!) | themossman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 07-12-2010 09:56 AM |
Is This A Good Price For Borla S-Type Axle Back & Magnaflow Tru-X 2.50" X-Pipe? | Black LS3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 01-20-2010 01:48 AM |
