08-17-2012, 08:55 AM | #1 |
Drives: 03 duramax 01impala 2010 2ssrs Join Date: Feb 2009
how much boost can i run
I want to run a smaller pulley just at the dragstrip with 110 race fuel. is 8# safe? is 10# safe boost , i don't want to run meth. i have a cai, lt, 3" exhuast and a maggie with 52lbs injectors. If 10# is safe, do i have enough injector pressure. Yes i will have a tune for this. 2SSRS ( how much hp can i gain with 110 race fuel?) thank you
08-17-2012, 09:06 AM | #2 |
Drives: Blown G8 GT Join Date: Apr 2010
I'm at 9lbs and my zr1 injectors are beyond maxed out.
I'm going with id850's. I think you will be too. |
08-17-2012, 09:53 AM | #3 |
Drives: 2010 A6 SS/RS Join Date: Sep 2009
I have 14 psi with stock shortblock good fuel and Jannetty tuning it. LPE system and ID 850's... call ted he will give you all the information you need...
Scott(Retired Navy)(Paralyzed Triathlete)
New Car 99 Camaro SS with Dart 427, F1x, Rossler 210, 9 inch and BS3... scary ride SOLD 2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass 1.51 60ft 10.08 136.78 mph JRE Built |
08-17-2012, 02:04 PM | #4 |
sounds like i better stick to 8# of boost, I don't want to change injectors yet. Does anyone know how much hp i can gain from 110 race fuel... 20 hp... 30hp?
08-17-2012, 02:27 PM | #5 |
I just got SLP 65lb injectors and conectors and I was told they are rated to 850hp. I have the Edelbrock supercharger and I'm going to put a 3" pulley on and a ZL1 fuel pump. I was told that I will be fine. I guess we will see next week. LOL
08-17-2012, 03:36 PM | #6 |
Drives: 2008Corvette Join Date: Feb 2012
We have a customers camaro we have been running with a stock shortblock 15psi,race gas,no intercooler, no methanol and 125mph in the 8th. Use some race gas(110 and up), and make sure the tune is spot on.
Chris |
08-26-2012, 01:06 AM | #7 |
just got back from the dyno... 8lbs looked great on the dyno and the 52lb injectors with 110 race fuel were at 70%. could try 10lbs of boost, but don't have another pulley... damm!..... oh, and 2lbs of boost and race fuel was worth 65 hp!
08-26-2012, 12:14 PM | #8 |
this engine loves 110 race fuel but you have to add timing and lean it out. but holy cow does it like race fuel!
08-26-2012, 12:21 PM | #9 |
Drives: 2010 Camaro Join Date: Feb 2010
08-26-2012, 01:27 PM | #10 | |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
So it doesn't seem like race fuel gave you much, everytime in the past when I changed pulleys and stayed on pump gas I would see around 25-30 hp inprovemnet for every 1psi until you get above 11psi that was the norm. I would think you should be able to get another 20-25 hp with timing and 110 octane.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
08-27-2012, 03:41 PM | #11 | |
The fuel pump will fall short as well. Horsepower is not a Product of Boost it is a Product of How much FUEL you can burn efficiently. Ted.
www.jannettyracing.com
08-27-2012, 08:04 PM | #12 | |
So larger injectors and meth are next |
Thread Tools | |
