08-12-2012, 03:49 AM | #1 |
Question about CEL codes. HELP!!!
Hello all. About a month and a half ago or so I installed (or had them installed ) BBK long tube headers. Shortly after I got a CEL, no biggie, its expected right? Anyway, ordered the trifecta tune and uploaded it last night. Started the car up and took it for a spin. CEL was off. Car really felt great, all is well.
Go to work today and the CEL comes back. Decide to check the codes with EZflash and they came up as follows. P0300 Cyl misfires P0302 Cyl 2 misfire P0305 Cyl 5 misfire P2187 System too lean at idle bank 1 (symptom of the LT headers?) P2189 System too lean at Idle Bank 2 (same?) I had never received any CEL till I installed my BBK long tubes. When it popped up I didn't think anything of it knowing that it would be due to the o2 sensors. Are these other codes normal for long tubes or something I should get checked out? The Cylinder misfire codes are kinda freaking me out. Any help would be appreciated! Thanks! |
08-12-2012, 09:45 AM | #2 |
Drives: 2018 Camaro SS 1LE, 2019 Camaro 2.0 Join Date: Sep 2011
Data log the car and send the log to me and also note the codes in the email please
08-12-2012, 12:15 PM | #3 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Did you get the ghost cam feature?
I believe some users have gotten misfire codes with that. After you datalog for BNR, I'd re-program with that feature turned off and see if this problem returns. |
08-12-2012, 01:04 PM | #4 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Are you running a good catchcan to keep the oil out of the combustion process? That will lead to missfires as well over time, and a failing MAF.
Send BNR a log and he can help. |
08-12-2012, 01:13 PM | #5 |
Yes I am running a catch can. Got that installed the same day as the longtubes actually. Ill datalog asap and email bnr. Question though. Im suspecting that this may be happening at cold start. It sounds a little funny when I first start it at the beginning of the day after sitting all night. Should I datalog from cold start? Is there anything in particular you want to see in the log?
08-12-2012, 01:54 PM | #6 |
08-12-2012, 05:55 PM | #7 |
email it to me at customersupport@badnewsracing.net (make sure if you didn't use the newest version of ezflash that I put up there a couple days ago, that you download it from my site and re-log)
08-12-2012, 05:58 PM | #8 |
I downloaded ezflash on Friday night. Should that be the correct version?
08-13-2012, 03:17 AM | #9 |
Emailed the log off this evening. Thanks again for your help!
08-13-2012, 06:23 AM | #10 |
Drives: 2010 camaro with fast lane stage 2 Join Date: Apr 2011
an overdue oil change will do that also check your oil and yes there is sa reflash for misfires on cold start gm came out with
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back |
08-13-2012, 08:51 AM | #11 |
Track > 1/4 Mile
Oh God please don't bring that up
How does the car drive, mainly when the rpms raise (like when accelerating) ? Does it misfire then? If so I'd say it's your MAF going out.
08-14-2012, 12:40 AM | #12 |
Had the oil changed two weeks ago or so, so I doubt its that. But I'll check anyway.
The only time I hear any kind of misfire is on cold start. Which sounds to me like a short sputter maybe? Then it warms up for maybe 30 seconds at 1000 or so rpms then goes down to 800 ish as normal and idles fine. It started doing that when i had the headers put on. I figured it was normal behavior with the headers. Anyway, other than that it runs normal. I'm taking it to my dealer Friday for some other minor work so I'm probably going to have them check it out while its there. Just in case. Hoping I hear back from bnr beforehand with some good news. |
09-18-2012, 09:22 PM | #13 |
RIDING ON AIR
Drives: 2010 2LT/RS Summit White Join Date: Dec 2009
whatever happened with this?
--John--2010 Camaro 2LT/RS, Summit White Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels |
09-19-2012, 12:23 AM | #14 |
Had a vacuum leak. Took care of it and all CELs went away.
Vararam | Ceramic BBK LT Headers w/ HFC | Custom MagnaFlow Exhaust | RX Catchcan | Vmax 3/8" Black Ice-O-lator | MagnaFlow Resonated X-Pipe | Trifecta Tuned | Stop Tech Slotted Rotors | White out Bowties | Black out side grills | Custom Badges | 22" American Racing Daytona | Polk Audio 6" & 6x9" | Kicker 10" with custom box | Alpline 400w 4 Channel | Alpine 500w Mono Channel
