05-25-2014, 03:39 PM | #1 |
Totally into it
Drives: '67 427vette/'11 Pacecar/'02 BMW ci Join Date: Feb 2011
Reading Dipstick after oil chage
Has anyone else had this happen? I change the oil. I replace with Mobile 1 and when I go to read the dipstick, I can't tell the level. The fresh oil is too clear. The whole stick looks shiny/oily. Tried waiting hours and hours, rechecking each time but no change. Finally I just measure how much I drained and make sure I put exact same quantity back in.
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
05-25-2014, 03:59 PM | #2 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
When I used Mobile 1 I would take the dipstick out and place it on a blue shop towel, where it is wet is where the level is.
For all the complaining about Royal Purple is just oil with purple die, that die comes in handy when you do oil changes. |
05-26-2014, 08:01 PM | #3 |
Drives: Oracle Camaro has all the bells & Join Date: Jul 2010
Are you only putting in 5 quarts? Its 6 quarts on my car.
05-27-2014, 07:33 AM | #4 |
Totally into it
Mine, L99, takes 8 quarts. I replaced the 7.5 quarts that I drained out.
05-27-2014, 07:38 PM | #5 |
Drives: '11 V6 RS Camaro Join Date: Feb 2014
I have the same issue in all my vehicles that I use Mobil 1.
05-28-2014, 09:49 AM | #6 |
376 cubic inches of fun
You need to get the new oil up to operating temp, then let it drain down for a few minutes, then check level.
By the way, my L99 takes 8 quarts, just like the manual says. |
05-28-2014, 11:40 AM | #7 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
Pull dip stick out and hold it in front of you horizontally, maybe slightly tilted down so the oil will not run uphill on the stick and show a false reading. Turn/rotate the stick so you are looking at it about a 45 degree angle so the light above reflects off of it and you will see the oil line clearly.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
05-28-2014, 12:14 PM | #8 | |
Grab a 12 pack of beer, pull the dipstick out and hold it vertically above the ground and start drinking the beer. However many beers you finish before a drop of oil hits the ground is how many quarts you have in your engine.* *Not a scientific method. |
05-28-2014, 12:17 PM | #9 | |
05-28-2014, 01:28 PM | #10 |
Good question, next Camarofest this will have to be tested in the parking lot. 12 oz beers or 16 oz beers for accurate oil measurement.
Think we can find volunteers? |
