04-01-2013, 12:45 PM | #1 |
Drives: 2011 Camaro LS IBM Join Date: Nov 2012
weird noise after HID install
this only occurs when the DRL function is on, i.e. during the day. It's intermittent, but when the DRL's are on, there's a weird noise, can't really describe it, but a hum, like maybe electrical interference, but only with the DRL enabled. If I turn the knob to parking lights or to full on headlights, it stops, and then I can turn it back to automatic, and it will usually stay gone. I have a 55 watt, AC digital ballast system, with a relay harness. Could the relay be bad? Or is it a grounding issue?
04-01-2013, 12:46 PM | #2 |
Drives: 2011 Camaro LS Join Date: Dec 2010
Where did you get your kit? What kind of bulb??
04-01-2013, 12:59 PM | #3 |
i bought them from a local shop, the brand is xenon. They are H13's.
04-01-2013, 01:02 PM | #4 |
Drives: 2010 V6 | M6 Join Date: Feb 2010
I also had the same noise when I installed aftermaket HIDs on my LS. It is some sort of electrical interference. I didn't want to use DRLs anyway so I got rid of the feature where the lights come on automatically at start-up.
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther. 2010 Camaro LLT (sold) 2008 Yamaha WR250X 2011 Nissan Armada 4WD Platinum |
04-01-2013, 04:06 PM | #5 |
Drives: 2011 Synergy Green Camaro LT Join Date: Jul 2011
yeah, ive gotten it on almost every camaro ive put hids on. It is the drl brain, sounds like its from behind the glove box. No lasting negative effects from it though
04-01-2013, 04:38 PM | #6 |
Your running 55w HID in your stock housings?? Ugh. Glad I don't have to get blinded by idiots like you around me.
04-01-2013, 05:17 PM | #7 |
Drives: 2013 1LE AGM 2SS RS M6 Join Date: Apr 2012
^ this
04-01-2013, 07:30 PM | #8 |
maybe you shouldn't be sitting in the middle of the road where idiots like me aim their headlights. It's the high beams (OEM halogen, too) that blind you in oncoming traffic or from behind you, not the bright low beams that go to the side and down low.
04-01-2013, 11:35 PM | #9 |
If you have HID in the factory location you do not have halogen high beams. When you install HID in a headlight designed for halogen like you have done it scatters light everywhere and blinds everyone else on the road. Not just people sitting in the middle of the road. Lol. Camaro housings are one of the worst ones for this stupid mod. Especially 55w. But it seems you have no clue what your talking about so I doubt your gonna understand what I'm saying.
04-02-2013, 10:43 AM | #10 | |
Have you actually seen how the light is scattered from one of these kits? I mean in real life? Not just in fairytale land, or on the internet? I have. I own them. I've sat in my driveway with the lights on in the dark and saw how the pattern is. I've been in front of my wife driving the car, and I wasn't blinded. I have the same cutoff line as I did with halogen, the light doesn't randomly go up into the sight line of other drivers. And I've also seen many cars with the aftermarket HID kits installed, and I've never been blinded by them. I have been blinded by idiots that leave their lights on high beam, where the beam pattern has been raised above the road level (by changing the source location, therefore, the focal point of the parabolic reflector, not the light itself), where it is directed into the eyes of oncoming traffic and into my side view and rear view mirrors. That's what blinds people. I'm an engineer, I understand focal points and light theory, and all of that. But I also know what I see. When I turn on my lights, it's the same pattern as the OEM halogens. Just because the light source is different, that doesn't mean that the light beams reflect differently and violate the laws of physics by being scattered everywhere. The Camaro doesn't have all of the diffuser patterns that some lights do, it's basically a clear lens with a parabolic reflector. Do you know why they use parabolic reflectors? It's because parabolic shaped reflectors concentrate the light to it's focal point. The light type doesn't change where that focal point is, so why would anything be different? Whatever trajectory the halogen light beams travel in, so do the HID light beams. The difference is the intensity and the color, not the laws of physics and how the beams reflect off of objects. That's the dumbest, ill-informed, statements anyone could make. Let's end the debate over whether or bad or good. The point of the thread was what was causing the noise, not how I'm "blinding" innocent drivers. |
04-02-2013, 04:44 PM | #11 |
I'm sure your an engineer. What kind?? copy and paste?? I have seen camaro housings with HID. Not good. And since a HID bulb has a different focal point your argument just sucks. If a reflector has a source of light from 2 different locations it will reflect the light 2 different ways. And how come you have no high beams at all??
05-26-2013, 05:17 PM | #12 |
Drives: 2012 camaro ss Join Date: Jul 2012
so did you ever get it fixed? If so What did you do
05-26-2013, 08:37 PM | #13 |
I never get flashed for having my hids on. They are however only 35w but the light does stay on the road in front of me and not distributed all over the place. The only vehicle I get flashed when driving is my hummer, but its lifted so the lights are up alot higher. And like soltero said, I've been driving in front of my Camaro with my wife following behind and I didnt feel blinded.
05-29-2013, 02:12 PM | #14 | |
