09-23-2011, 05:25 PM | #1 |
First Service
Hey guys,
When should I first service my 2012 Camaro? I know that its either the oil life goes down 20-22% but after how many miles should I take it in for its first service? |
09-23-2011, 05:44 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
you'll get all kinds of opinions..........3000 miles is when i changed mine and every 7500 thereafter
09-23-2011, 06:02 PM | #3 |
thats your first service? at 3000? isn't that to long?
09-23-2011, 06:42 PM | #4 |
Drives: 2010 1SS/RS Imperial Blue Metallic Join Date: Sep 2010
i changed mine the 1st time @ 2000 miles then every 4000 after using mobil1
09-23-2011, 06:49 PM | #5 |
Drives: 2010 2lt chevy camaro Join Date: Jun 2011
i do a change every 3,000 also! thats the factory pamphlet recommendations.
09-23-2011, 08:02 PM | #6 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
I changed my first oil at 4200. Felt a little sticky then. now Mobil 1 EP every 3000, no later.
09-27-2011, 01:15 PM | #7 |
Drives: GM Vehicles Join Date: Jun 2010
In your owners manual it shows in section 10 on page 13 that:
This vehicle has a computer system that indicates when to change the engine oil and filter. This is based on a combination of factors which include engine revolutions, engine temperature, and miles driven. Based on driving conditions, the mileage at which an oil change is indicated can vary considerably. For the oil life system to work properly, the system must be reset every time the oil is changed. When the system has calculated that oil life has been diminished, it indicates that an oil change is necessary. A CHANGE ENGINE OIL SOON message comes on. You can go based off of this system or you can go off any sort of mileage or driving parameters you may choose. They only really big stipulation that I can think of is the type of oil you would want to use. The manual recommends you use Dexos specified oils. Notice: Failure to use the recommended engine oil or equivalent can result in engine damage not covered by the vehicle warranty. Check with your dealer or service provider on whether the oil is approved to the dexos1 specification. The manual also states you should be using 5w-30 oil unless you live in an area that gets bellow -20 degrees Fahrenheit. In that case you would use 0w-30.I hope that helps to answer some of your questions. Jeff Morris, Chevrolet Customer Service |
Similar Threads | ||||
Service Struggles @ Dealer w/ 2LT/RS | Grandeos | 5th Gen Camaro SS LS LT General Discussions | 8 | 09-18-2010 10:39 AM |
Dealer service, that outta teach me to use a free coupon.. | Swytch | 5th Gen Camaro SS LS LT General Discussions | 24 | 08-31-2010 03:42 PM |
XM Radio Service Issue "BE AWARE" | dalasD | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 89 | 06-20-2010 08:34 PM |
Frustrated with GM & Dealers' Service | eckerj | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 20 | 04-27-2010 12:44 PM |
Piston to Valve Clearance? | My First Camaro! | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 08-18-2009 07:26 PM |
