02-09-2014, 01:05 PM | #1 |
Drives: 2011 Camaro Lt Bumble Bee Join Date: May 2012
Proper PSI for my tires??
I got some Haida HD921 tires which is on 20's. I normally run 35psi or thereabouts.
The tires I've got says on there max psi is 51. Hmm any suggestions where I should find my happy medium?? I'm an aggressive driver and turn corners pretty good with my pirellis's. Suggestions?? Treads on the new one is about 5k, so lots of life left. Thanks!
Live life to the fullest every day, for tomorrow may never come. I am living proof. I am a heart transplant receipent!
2nd chances do not come around very often. Become an organ donor!! ------------------------------------------------------------------------------------ Chevy Camaro all the way!! |
02-09-2014, 01:16 PM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
the pressure on the side of the tire is exactly that....MAX TIRE PRESSURE. its NOT normal RUNNING Pressure. the value that is on the door jam of your car is what you should be running. the fact that you normally run 35 psi.....that is fine.
