#Camaro6
AWE Tuning
Old 05-11-2017, 09:25 AM   #1
jrs580
jrs580's Avatar
Drives: 2016 2ss
Search bar in camaro 6 is useless on my phone.
Is anyone else having this problem? There is no way for me to search this forum on my phone. I have to be on the computer for it to work.
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 05-11-2017, 09:26 AM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
Just used it with no issue just now, has always worked fine on my phone.
jpsuperman81 is offline   Reply With Quote
Old 05-11-2017, 10:05 AM   #3
mattyb65
Drives: 2017 Camaro 2SS Hot (damn) Red
Yes, but the workaround would be clicking on search and when you get the drop down, click on 'advanced search'. It will bring you to the search page, which will work as designed.
2017 Red Hot 2SS
The Sequel - Bigger and Badder
8.26.16 - 1100
8.31.16 - 3000
9.12.16 - 3400 TPW 9/19
9.20.16 - 3800
9.22.16 - 4300
9.23.16 - 4B00
9.30.16 - 4200
2012 Victory Red 2LT/RS
6.27.11 - 1100
7.22.11 - 2000
7.26.11 - 2500
7.29.11 - 3300 - 8/8 TPW
8.03.11 - 3400
8.10.11 - 3800
8.10.11 - 4B00
9.20.11 - delivered
mattyb65 is offline   Reply With Quote
Old 05-11-2017, 10:08 AM   #4
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Use Google and type camaro6 and then what you are looking for. Works fantastic!! Works so much better than the sites search.
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst
Michigan1LTRS is offline   Reply With Quote
Old 05-11-2017, 10:44 AM   #5
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
Both true
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 05-11-2017, 10:46 AM   #6
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
My work around is typing what I will search for, copy it, then you hold your finger the actual text field input for the search. It will pop up with the paste option. Works every time for me. Annoying to have to do it that way but it works
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 05-11-2017, 11:30 AM   #7
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
To be specific, you want to use Google site search. Example:
Parts in trunk site:camaro6.com
The "site:camaro6.com" tells google to only search that website domain. Works 100X better than the forum search.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 05-11-2017, 11:36 AM   #8
LuvMI
Lovin the growl...
LuvMI's Avatar
Drives: 2018 2SS
No probs so far.
LuvMI is offline   Reply With Quote
Old 05-11-2017, 12:20 PM   #9
SF Giants
SF Giants's Avatar
Drives: 2016 Camaro 2SS
Another workaround is to hold your finger on the search button for a couple seconds, then click "open in new tab". That will give you a search page that you can type on.
SF Giants is offline   Reply With Quote
Old 05-11-2017, 12:31 PM   #10
srcstc
Are you using the Tapatalk app? The search doesn't work for me either on there. But on the mobile site it works fine.
srcstc is offline   Reply With Quote
Old 05-11-2017, 12:40 PM   #11
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
Is there even a mobile site for Camaro6? When I view these forums on my phone, it's the same as on my desktop. Super hard to read and very small. I assumed the version of vBulletin that they are using doesn't support showing a "chunkier" layout for mobile users like a lot of other forums do. I also just now visited this site with my browser's user agent spoofed so it would look like I was requesting the site from a mobile phone, but it made no difference.
RenegadeXR is offline   Reply With Quote
Old 05-11-2017, 12:46 PM   #12
srcstc
Yeah you're right. There's no mobile version.
Old 05-11-2017, 07:41 PM   #13
Wolvie70
Wolvie70's Avatar
Drives: 2016 2SS, Summit White, A8, NPP
From the posts I see you might be the first to try and search ever
Wolvie70 is offline   Reply With Quote
Old 05-11-2017, 09:29 PM   #14
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Yeah, I have to use one of the work arounds listed above.
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
