Old 07-24-2013, 11:23 PM   #1
Puladulaman
Drives: 2010 cyber gray SS/RS
Bolt on camaro need help lost 6mph in 1/4 don't know why
Please help ! I have a SS with cam intake header exhaust tune nitto nt05s it's putting out 458 to the wheels I ran the car a year ago in florida to palm beach international raceway some of you might know it as moroso and ran a 12.4 with a 2.2 60ft at 118 felt great for such a bad 60ft until the 3rd run i snapped a joint on a axle but now a year later and some 1000hp axles i ran it in Michigan to Milan dragway got a 2.08 60ft ran 12.5 at 112 the car trapped 110 111 stock I'm not sure what the problem is other then maybe the cars been sitting too much I only get to drive it once a week if I lucky some times it goes 2 weeks but had a 35 mile drive to get to the strip and got on it a few times to clear it out somewhat and I can't say it was the weather because in Florida it was 80 degrees and here in Michigan it was 65
PLEASE HELP ASAP before I put a 200 shot on it lol
Puladulaman is offline   Reply With Quote
Old 07-24-2013, 11:27 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
NT05s? Or NT05Rs? 12.4 with a cam something is wrong! But this type of summer weather is going to effect you big time! Is it an auto or stick?
62nalide is offline   Reply With Quote
Old 07-25-2013, 12:41 AM   #3
Puladulaman
Stick and Nto5s guy didn't know there was a difference when he put the order in and just got left like that and about the weather it was 65 degrees it was almost perfect I'm just really confused on how I'm only running 112 trap I mean the first run I thought I must of hit the breaks to soon lol
Old 07-25-2013, 12:43 AM   #4
Supercharged SS
Drives: 2010 Camaro
Do you log your passes?
Old 07-25-2013, 01:18 AM   #5
Puladulaman
Here's a pic of the ticket
Old 07-25-2013, 01:19 AM   #6
Puladulaman
Don't have a pic of the old 12.4 118 pass anymore
Old 07-25-2013, 07:11 AM   #7
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
What is the elevation on that track? PBIR is barely above sea level. Also what was the humidity level? It could be a very dry 80 and a very muggy 65 and make a huge difference. Lastly, were you finishing in same gear on both tracks?
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-25-2013, 07:46 AM   #8
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Install the 200HP shot & call it a day.
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 07-25-2013, 08:20 AM   #9
Kelly@PCMofNC
Drives: 2010 RS/SS
Could be a lot of things, my first question would be what the DA was on both days, temperature only tells you a small part of that story.
I'd also want to see a datalog of it going down the track now, that gives you a lot of good information such as...is the fueling off, is it pulling a lot of timing for some reason, etc
Kelly@PCMofNC is offline   Reply With Quote
Old 07-25-2013, 08:32 AM   #10
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
I actually just went through this. I have a pretty medium cam, nothing too crazy, but I also have PTB, Headers, UD Pulley, Cutouts, and CAI. Got a 12.5@111mph on stock tires with a 2.06 60'. Took my car to get retuned by Rhino79 (a reputable tuner in AR) and he found that the stock timing tables were left, rev limited had not been raised, just a bunch of stuff. He picked up about 20-25 hp & tq for me.
I would definitely look at the tune first and see what is going on with it. I haven't been back to the strip since the retune, but the car feels like it pulls a hell of a lot better than before.
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 07-25-2013, 09:06 AM   #11
Puladulaman
Here's what I came up with but numbers are probably off a bit because I'm guessing on humidity...the weather forecast I got only gave me the high the low and average not the hourly, and barometer could be off a Lil bit because it was a graph but not vary detailed. And the tracks sea level is 672 ft
Old 07-25-2013, 09:11 AM   #12
Puladulaman
Yea something's was wrong there to because I feel our cars should gain more then 1-2mph then stock lol and my tune is the same since the Florida runs
Old 07-25-2013, 09:42 AM   #13
Juiced1
Drives: 2012 2SS CAMARO 45th
I would do some data logging first. I would guess that your timing is being pulled some which would cost you some top end power. Might have been something as simple as bad gas or something more serious. Either way, if you're already getting knock that 200 shot might not be the best idea.
Juiced1 is offline   Reply With Quote
Old 07-25-2013, 11:21 AM   #14
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
a bolt on car making that much power is not right to begin with and trappin 118 in a bolt is not right either. unless u have a bunch of other stuff u done to cut weight and this and that. 112 sounds about right to me. time is caculated so the drag strip could of been off a little. i know that i see a 1-2 between the tracks i go to. with da being around the same. but if da was in the -. then 118 could happen. So now ur getting in normal air 2000 3500 for this time of year.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
bolt on, drag race
