03-26-2012, 12:10 PM | #1 |
Freightrain Coming Ur Way
Drives: V8-1968 & V6-2000 & V6 2010 Camaros Join Date: Feb 2010
Steering wheel audio control diagram
Hello. I searched with no luck...
I'm trying to find a wiring diagram of the connectors/wires that are on the steering wheel only, and connect the controls. I'm trying to figure out if it would be possible to put the just "search" button on the left hand side where there is an empty slot next to the cruise control.
Do you serve a purpose, or purposely serve?
03-26-2012, 12:12 PM | #2 |
knows 2 facts about ducks
I *think* that it is a single data wire that controls the buttons but I don't know that for sure.
03-26-2012, 04:02 PM | #3 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
Is this the diagram that you was wanting?
Caddy
03-26-2012, 04:07 PM | #4 |
yes thank you
03-26-2012, 05:03 PM | #5 |
If my electronic math hasn't failed looks like you just need a 2935 resistor and switch between the pink and light green wires.
Caddy
03-26-2012, 05:34 PM | #6 | |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
You see all the numbers above the switchs, there resisters with a set value, when you push any switch it sends a signal on the pink wire for the switch you pushed, to the BCM and it does all the work. |
03-26-2012, 06:06 PM | #7 |
Ok I was thinking it would have to be 2935 ohms for the source to work since the resistance is in series.
Caddy
03-26-2012, 08:40 PM | #8 |
I ordered the parts to test today will let you know the outcome.
PS this summers job to make this radio work in the older cars. |
03-26-2012, 08:41 PM | #9 |
By my calculations, it's 3025 ohms. Yes, it should work if you get the correct value resistor hooked up to a switch.
03-26-2012, 09:06 PM | #10 |
Drives: 2011 SIM 2SS/RS Join Date: Nov 2009
03-26-2012, 09:10 PM | #11 |
so excited!!!
03-26-2012, 09:16 PM | #12 |
Drives: 2011 2ss/rs Join Date: Nov 2011
03-26-2012, 09:25 PM | #13 |
03-26-2012, 09:33 PM | #14 |
I meant to quote the stereo picture. Damn tapatalk I hate it. It says 1LE that's the track pack?
Similar Threads | ||||
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles | steeleshark2 | Tuning / Diagnostics -- engine and transmission | 11 | 04-08-2020 10:49 PM |
steering position, wheel speed, cruise control brake switch... | hapisok | Tuning / Diagnostics -- engine and transmission | 8 | 10-24-2011 08:07 PM |
For sale 4 pack guage cluster, steering wheel control, and pdim | manwitadream | Audio / Visual / Electronics/ Gauges / Nav | 13 | 08-20-2011 03:35 PM |
Tires loosing pressure | joepitt | Wheels and Tires Talk Sponsored by The Tire Rack | 22 | 12-11-2010 05:00 PM |
USB port | The_Stache | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 85 | 09-20-2009 01:44 PM |
