03-18-2024, 06:05 PM | #1 |
Drives: Chevy Suburban Join Date: Aug 2023
Headers questions
Hey all, I've got a new pair of Kooks long tubes arriving in a couple days.
Is anyone here using a heat wrap for the starter? Is it a necessity? Thanks in advance. 2010 SS with cai. |
03-18-2024, 07:18 PM | #2 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
I have a 2015 ss and I have had headers since 20k miles and I now have 54k on it for over 4 years and I personally haven't had any problems with heat soak with the starter and I have, cam, heads, gears stall etc. Basically everything except power adder and I still have the original starter with no problems but others have had problems.
I bought the heat wrap from DEI because others said it was a problem but never installed it. Haven't needed it and I live in 105+ summer Texas heat but yes the headers will make the engine bay hotter. If you are that worried about heat soak I would recommend ceramic jet hot coating the headers before installing them. Just my 2 cents. |
03-18-2024, 07:18 PM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Never used heat wrap in the starter area. Did put better grounding on the turbo car. It starts like a champ. No extra grounding on the vert and it's starter is lazy after initial startup. Will be adding some grounds in the near future.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-18-2024, 08:55 PM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I live in the Texas heat too and haven't had any problems with heat soak either but like others have installed the extra grounds as well.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
03-19-2024, 01:20 PM | #5 |
On my Camaro I have done the extra ground cables to do away with the "hot start" issues. I ran mine about 9 years with the LT's and original starter with no issues, until the starter got weak, and the hot start problem reared its ugly head. Replaced the starter, and again, extra grounding cables and I did use the DEI heat wrap on the new starter just to be safe.
03-19-2024, 03:31 PM | #6 |
Started#gottalovethatblue
You spent the money for great headers, send them to get ceramic coated. You won't have to worry about exhaust wrap wearing out and the headers will look like new from now until forever. I have ceramic coated Kooks headers that are almost 9 years old and they look as good as day 1.
03-19-2024, 03:45 PM | #7 | |
Drives: 2010 Camaro Join Date: Dec 2022
What he said. I recommend Jet Hot. Looks better, will last longer, and reduces heat.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
03-19-2024, 04:34 PM | #8 |
Drives: 2013 ZL1 Join Date: Sep 2021
I have ceramic coated headers never had a problem with heat soak but I did end up putting a starter blanket on it-just in case.
03-19-2024, 09:45 PM | #9 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
The starter has a heat shield on it
03-20-2024, 02:27 AM | #10 |
That's a good point, mine does.
