Old 04-15-2011, 10:27 AM   #1
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
Belt Slip!!!
I have the stock maggie belt up front with a 3.4 pulley and I believe I have belt slip. On my two step I am seeing only 6-7psi and when i'm on it in third I'm only getting 2-3psi. On the 3.6 pulley I was seeing 8psi on the two step and 9psi midrange falling to 7psi by redline. So all in all what can I pull off without going to an 8 or 10rib setup? Larger Idler Pulley? Shorter Belt? What options do we have here?
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 04-15-2011, 10:35 AM   #2
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Larger idler, stronger aftermarket tensioner (billet)
Tensioner is a big deal. Katech makes a pretty nice one, I know Jannetty has fabbed them for maggies too. Plus is that you can easily swap to 8 on the tensioner in the future
Ovenmitt is offline   Reply With Quote
Old 04-15-2011, 10:42 AM   #3
boostedyards86
so where can i find one of these larger idler pulleys? And thank you I wasn't aware aftermarket tensioners were in existence.
Old 04-15-2011, 11:50 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
2-Steps and Supercharger Belts and Tensioners Don't Play Nice together, I have seen many a shredded Belts and broken Tensioners in my day.
If you have the right belt length and the Idler pulley in the Right Spot Belt slippage with a 3.4 should not be an Issue.
We have a Super HD Tensioner available that we are running on SuperchargedSS's Car, there are pics in the Thread.
http://www.camaro5.com/forums/showth...&highlight=psi
Do Not go to a Mechanical Tensioner they don't work with Superchargers.
The belt is basically a rubber band and when you put it under strain it stretches, and you need a spring loaded tensioner to take up the additional length under power.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-15-2011, 06:53 PM   #5
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Oh! no cog drives for those top mounts.
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 04-15-2011, 08:00 PM   #6
Huck1974
Drives: 2011 2SS
gatorback
Huck1974 is offline   Reply With Quote
Old 04-16-2011, 12:13 AM   #7
boostedyards86
just picked up a half inch shorter belt. seems to do better. 9psi on two step now. JRE i am interested in what you have to offer and would like more info.
Old 04-16-2011, 12:48 AM   #8
Supercharged SS
Drives: 2010 Camaro
I used a gates green belt with the 3.4 and didn't have much slippage at all. It made over 10 psi. Ask Ted which belt. He should know.
Old 04-16-2011, 01:04 AM   #9
boostedyards86
ya i'm just gonna grab a gatorback when i get the chance. when the fuel switch happens then ill do the 3.2 pulley and see how interesting things can get.
Old 04-16-2011, 07:00 AM   #10
JANNETTYRACING
With a 3.2 you will need more of a Tensioner like on Jamies Car.
Give me a call and I will set you up with one.
Ted.
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
Billet Belt Tensioner in Stock MTI Racing Kevin Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 04-19-2012 07:46 AM
KB 2.8LC (black/polished) from Santa aka TPE sting808 Forced Induction - V8 50 02-17-2011 01:16 PM
TBS on Belt Noise venice17517 Forced Induction - V6 1 01-29-2010 07:51 AM
