11-18-2011, 07:23 AM | #1 |
Drives: 2010 Camaro 2LT RS Join Date: Nov 2011
Help with removing valve stem..
Need help removing the valve stem, TPM is off and tire is off. Do I need a valve stem removal tool. Can I just use regular tools. Searched online but wanted to get you guys' opinion first. Thanks.
11-18-2011, 07:35 AM | #2 |
NEcamaro5
I'm pretty Shore you need the tool for valve stem remover.
11-18-2011, 04:36 PM | #3 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
Technically, u need the tool, but if your tire is off you can cut the bulb of the stem, fom the inside and pull it out with pliers.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
11-19-2011, 06:51 AM | #4 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
I've never had much luck removing those in order to re-use them. Buy replacement rubber stems if you can. To remove them, I just slice off the bottom with a flat razor.
Fquick.com/NineBall
Thread Tools | |
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
Acronyms at C5 | hokie2012 | 5th Gen Camaro SS LS LT General Discussions | 34 | 08-10-2011 03:56 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
