05-05-2021, 03:05 PM | #1 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Let's see your shifter "I'll go first"
Like the title says, let's see your shifter.
Here is mine It's the hurst shifter with the optional button side. I have the buttons set up as my tap shift. I like it.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
05-05-2021, 03:14 PM | #2 |
Drives: 2011 RS 2LT Join Date: Dec 2020
I like it, very cool.
05-05-2021, 03:18 PM | #3 |
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
05-05-2021, 03:19 PM | #4 |
05-05-2021, 03:34 PM | #5 |
Drives: 2016 1SS Join Date: Apr 2012
The shifter of all shifters. Awesome!
- Sean Sales and Support |
05-05-2021, 03:47 PM | #6 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
05-05-2021, 04:27 PM | #7 | |
05-05-2021, 04:55 PM | #8 | |
05-05-2021, 05:16 PM | #9 |
#teamGPI
Drives: 2010 Camaro SS Join Date: Aug 2020
Cool hurst!
05-05-2021, 05:49 PM | #10 |
USA-1
I have the same as L99Maro!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
05-05-2021, 07:56 PM | #11 |
Custom shifter made by a guy on this site. OEM manual boot and carbon fiber knob. No buttons, just push down on the knob to get past the locks.
05-05-2021, 08:03 PM | #12 |
BBK Long tube headers, Hi flo cats, straight pipe muffler delete with j-pipes. K+N CAI, Soler Performance Ported Throttle Body, Soler Performance Throttle Controller, Phantom Grill, MGW flatstick shifter. 3.91 Gears, Ported Rod Mod Intake, ZTA Spoiler, Rohana RC22 20x10 20x11.
05-05-2021, 08:07 PM | #13 |
Started#gottalovethatblue
How did you get the buttons to be your shift buttons? What did you have to reprogram or rewire? That's an awesome idea! I just installed this shifter minus the side buttons.
05-05-2021, 08:47 PM | #14 |
Drives: 2011 Camaro Convertible V6 Join Date: Mar 2021
