11-23-2009, 08:38 AM | #1 |
Drives: 1SSRS RY L99 Join Date: Aug 2009
Need help with changing spark plugs.
Hey guys, looking for some advice. I will be installing shorties at some time in the near future. I will be removing the spark plugs. I don't work on cars, I have been a diesel tech for 15 years and I have never actually installed spark plugs before! Does anyone know what the proper torque is? What is the proper gap? Does anyone use a bit anti-seize on the threads? Anything else I should know?
Thanks! |
11-23-2009, 08:45 AM | #2 |
o come on
Drives: 06 GTO Join Date: Nov 2008
I don't know what they are torqued to. But if you are taking the original ones out and just putting them back in you shouldn't have to regap them. And yes put a dab of anti-seize on them. The torque info seems like it may been in the owners manual.
06 GTO with three pedals like it should be
11-23-2009, 09:27 AM | #3 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
IIRC its 11-12ft lbs
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
11-23-2009, 09:42 AM | #4 |
Drives: 2010 2SS/RS Black Join Date: Mar 2009
Yes, anti-seize is a must.
Not sure about the gap to be honest, would have to look in the manual for that.
Understeer, Oversteer, Wheel Alignment (Camber etc), Torque, Horsepower, Camaro
Fold for team 11108 to help find a cure! Folding@home Stanford's Research DC Program. |
11-23-2009, 09:45 AM | #5 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
11-23-2009, 09:46 AM | #6 |
Drives: Black 2SS Join Date: Oct 2009
The factory plugs are the iridium plugs set at .040, you are not supposed to gap this type of plug due to the size of the electrode.
11-23-2009, 10:59 AM | #7 |
I checked the owners manual, nothing about torque that I could find. Only AC Delco PN's, and the gap of 0.040". I did some research on those plugs and gap is set when the center electrode is set into the ceramic. Other forums are still saying to check just to be safe. I checked around some other manufactures and did some cross reference to find more info. If you cross the part number in the manual to the latest Delco number you get 41-985. No torque info on the Delco site. If you cross to Bosch and Autolite and read the specs the plug has 14mm threads, tapered seat, 5/8 hex. In an aluminum head they both say 7-15 ftlbs.
http://www.autolite.com/pdf/TorqueSpecs.pdf |
11-23-2009, 12:53 PM | #8 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
If you use anti-sieze on the plugs when reinstalling/replacing them, I would use the 7 ft-lb rating if you're torquing them with a wrench. The 15 ft-lb rating is witout anti-sieze. I prefer using anti-sieze.
11-23-2009, 02:02 PM | #9 |
Yes, very true. I am a heavy truck tech by trade. I use anti-seize whenever I can. You will no believe how quickly or bad some bolts and parts seize on big rigs.
11-23-2009, 06:38 PM | #10 |
Actually, how do those heat shields come off around the boots?
11-23-2009, 07:14 PM | #11 |
Madman
The shields should just pull off as well
11-23-2009, 08:19 PM | #12 |
Drives: 2010 2SS RS CGM MN6 GFX Join Date: Aug 2009
Grab and tug holding on to the metal boot.
Be super-careful when you reinstall the plugs. They are a little tricky to line up when you contort yourself to reach down in the engine bay. Gently hand-tighten the plugs all the way until they are snug, then use a wrench. It's easy to start off cross-threaded... not that I've ever done that before! |
11-24-2009, 02:13 PM | #13 |
Thanks for help everyone!!!
Thread Tools | |
Similar Threads | ||||
Pulstar Spark Plugs | hollywoodGU | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 72 | 08-26-2015 09:14 PM |
LS3 spark plugs | restodaveny | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 8 | 05-18-2009 11:36 AM |
Nitrous oxide and Challengers | Superman09 | General Automotive + Other Cars Discussion | 16 | 01-29-2009 08:14 PM |
