01-12-2012, 07:15 AM | #1 |
Drives: 2012 Chevrolet Silverado 4x4 Z71 Join Date: Dec 2009
Any other additions to my suspension upgrade?
So far I have Pfadt trailing arms and subframe bushings installed on the car. Yesterday,I recieved my Pedders coilovers and 27MM front and rear swaybars (endlinks are on back order,should be delivered next week?).
What other parts would everyone suggest to aquire this winter to add to the suspension upgrade? Not looking to build a race car but rather a VERY spirited street car. All suggestions appreciated,even vendor input. Thanks everyone.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71. |
01-12-2012, 07:33 AM | #2 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
you have the basic "necessities" covered. Go have fun, drive very "spirited" and see what, if any changes are needed. There does come a time to enjoy all the hard work, I think you are there.
01-12-2012, 07:53 AM | #3 |
Adjustable toe rods, lower control arms and sub frame connector.
01-12-2012, 08:06 AM | #4 |
Drives: 2010 1SS Join Date: Jan 2010
Depending on how low you go with your coil-overs you may need some type of camber correction for the rear. You can use camber bolts or a lower control arm to resolve this issue. With your amount of power I would also put a set of toe rods on the car. It sounds like you have minimized the deflection in most of your suspension components but your toe rods are still lacking. You can upgrade the bushings in your OE toe rods but it's usually only a few dollars more to just replace them with aftermarket toe rods that already have better bushings. We have 3 variations to the toe rod - non-adjustable, adjustable street, and adjustable race. For street applications I would stay away from the race version. If you have any further questions, don't hesitate to ask!
01-12-2012, 01:38 PM | #5 |
Bump for any other thoughts or suggestions.
And thank you to the folks that have already commented,I appreciate everyones input.
01-12-2012, 03:44 PM | #6 |
Drives: Camaro Join Date: Jun 2009
I would definitely add castor bushings to your combo. (Not a must but I would recommend castor eccentrics as well)
If you plan on driving it hard and/or making any serious power, than diff bushings are a must as well. Please feel free to give us a call with any questions, we sell and stock all the major brands. Thanks Mike Haddad 310-412-8032 |
Thread Tools | |
Similar Threads | ||||
I need Help Choosing a Suspension Upgrade. | 2012camaro2SS/RS | Suspension / Brakes / Chassis | 36 | 12-21-2011 01:30 AM |
Which Mod First? Cold Air Intake and Tune or Suspension Upgrade? | CamaroFemme | 5th Gen Camaro SS LS LT General Discussions | 14 | 12-05-2010 11:50 AM |
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 02:28 PM |
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! | Circuit Motorsports | Suspension / Chassis / Brakes | 99 | 05-24-2010 04:21 PM |
