10-01-2009, 10:36 AM | #1 |
Drives: 04 sentra, 2ss Join Date: Apr 2009
strange alarm w/ tps
Ok i was driving home and i drove past a construction site. Then the low tpms alarm went off w/ low tire pressure in the rear. i pulled over and saw a small nail in middle of rear d/s tire. Now i have road hazzard warranty but i figured i can just patch it up and be on my way.
So i drive to a really trust worthy tire repair and they inspect and tell me the nail didnt go into the tire. So now im puzzled why would the tps go off. I gave him a tip and go home and reboot the tpms as per manual and go around the whole car waiting for the honks. i put in 36 psi cold. Now i will see if it hold the air. Did this happen to anyone here.????? thanks for reading joey |
10-01-2009, 11:46 AM | #2 |
Drives: 2010 camaro ss Join Date: May 2009
my shop has seen 100fold increase in tpms issues this last week alone,it was the first week the temps dropped at night,sensors see a low air pressure when cold and turn on the light,so really what started as low pressure ends up almost normal once you drive on it for a few miles,what weve found is most people dont have there pressure checked reg. so they get down to 32 psi warm and park at night it gets cold and bam its reading 28 psi in the morning and the light comes on,check the pressure when tires are warmed up and never go above the factory settings people.
10-01-2009, 12:08 PM | #3 |
Dances With Mustangs
The factory settings are not "limits" but rather "in the middle" choices usually for comfort and ride. You won't get your best gas mileage with the factory tire pressure settings. The tires can handle more than the factory settings. You can safely go 4-6 lbs above the recommended factory settings which will increase your gas mileage, give the car more of a feeling of being in contact with the ground.
I usually drive around until the tire temps are up to normal then check the pressures and set them warm. I know some people say set them cold but I don't drive around on them cold; they are always warm once you start driving so that's the way I set them. I have mine set at 40 lbs per tire and it's usually good for 1-2 mpg better gas mileage. The steering feels more precise too.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
10-01-2009, 12:30 PM | #4 | |
To All Veterans
Drives: 2010 2LT RS Inferno Orange Join Date: Sep 2009
10-02-2009, 07:54 AM | #5 | |
Onechuck
Drives: 2010 Camaro IBM 2SS\RS SC & Cammed Join Date: May 2009
10-02-2009, 09:55 AM | #6 |
Drives: IOM 2SS Join Date: Sep 2009
Use nitrogen in your tires and you wont have to worry about temperature variation.
10-02-2009, 10:01 AM | #7 |
I've got nitrogen in mine, and I've still noticed a variation. A lot LESS of a variation than with just air, but still a variation (after all, nitrogen is still a gas and WILL still expand and contract with temperature changes).
10-02-2009, 10:18 AM | #8 |
Drives: 2SS/RJT/A6/Received 09/09/09 Join Date: Jun 2009
Over inflation may result in premature tire wear in the center tread area. At $400 a pop its best to use the recommended inflation pressure.
Similar Threads | ||||
Need help with alarm system! | Camaro91 | 3rd Generation Camaros | 1 | 09-30-2009 03:06 PM |
Alarm sensitivity | RoyalKev | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 1 | 08-11-2009 10:49 PM |
Question about the alarm??? | Hydro FROG | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 07-11-2009 01:29 PM |
Engine Alarm!!!!! | Stylish | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 31 | 07-04-2009 03:48 AM |
Alarm in a box | Vash | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 1 | 05-31-2009 10:10 PM |
