Old 01-15-2015, 11:45 AM   #1
nashstat
Drives: 2SS Camaro
Opinions on how much brakes I have left
Hello everyone -
I am not an expert in this stuff and would appreciate your opinions on this. I own a 2010 SS/RS with around 35k miles (barely drive it here in SF).
I wanted to get your opinions on how much brakes I have left. I am posting two images, the first is the front and the second is the rear. I am scheduled to go in to get my pads replaced with OEM parts a week from today, next Thursday which will include surfacing my rotors.
Do you guys think I have a week left of normal freeway driving brakes in them?
Thank you!
nashstat is offline   Reply With Quote
Old 01-15-2015, 11:59 AM   #2
TECHTURTLE
TECHTURTLE's Avatar
Drives: 2016 Camaro 2SS
They will squeak but you should be okay.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 01-15-2015, 12:49 PM   #3
nashstat
Drives: 2SS Camaro
Thank you sir!
Old 01-15-2015, 05:03 PM   #4
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
You'll be fine. If they start squeaking, you can always bend the tab back so it doesn't mark up your rotor. They may be able to resurface and reuse the rotors that way.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 01-15-2015, 05:11 PM   #5
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Time for new pads!
Pedders Pace Car Kit with ZL1 sway bar conversion & camber bolt kit.Lowered 1.5". 1LE tires & wheels. CAI air intake. Anvil CF rear spoiler.MGW shifter. 1 7/8" Kooks LT headers & HF cats.V-Max ported TB. Tuned.
rockrau is offline   Reply With Quote
Old 01-15-2015, 10:23 PM   #6
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
If you're down to your wear indicators, I'd replace the pads right away.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 01-15-2015, 10:29 PM   #7
402
Drives: Camaro
You have some decent life left, you will be just fine.
402 is offline   Reply With Quote
Old 01-16-2015, 01:11 PM   #8
nashstat
Drives: 2SS Camaro
Thanks everyone! I ordered the OEM pads from Amazon/GMPartsDirect along with the caliper bolts. Should be all done by next Thursday!
I appreciate you guys' responses on this.
Old 01-16-2015, 01:43 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
You'll be fine until next week, but you're definitely getting down there.
Best regards,
Tyler
888-308-6007
Old 01-16-2015, 04:39 PM   #10
rockrau
rockrau's Avatar
If you do not cut or replace the rotors there is no need for the bolts.
Old 01-16-2015, 06:12 PM   #11
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I wouldn't have the rotors cut/resurfaced, unless they're warped. You only reduce their serviceable life doing that and it's not needed. Also, like said above, you won't need caliper bolts then. The brakes pads can be replaced without removing the caliper.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 01-17-2015, 08:34 PM   #12
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
If they really are warped, you might as well just replace them. If they're down close to the "minimum to machine to" thickness, replace them.
Is there indication of how much the rotors have already worn, such as at the outermost or innermost edges of the portion swept by the pads? Can you measure the thickness inside the area swept by the pads?
I'd cut rotors that have scoring that you can catch a fingernail on, just to make sure that the rotor surface starts out flat again (like the friction surfaces of the new pads will be). This assumes that the scoring can be removed without having to go all the way to the "min to machine" thickness.
Norm
Norm Peterson is offline   Reply With Quote
Old 01-18-2015, 07:27 PM   #13
nashstat
Drives: 2SS Camaro
I don't think the rotors are warped just by the break pedal feel of the car. There is no vibration, in fact the braking is fairly smooth considering the pads are almost worn out.
However almost every guide that I have read advises to re-surface the rotors by a small amount to get the most out of your new pads.
Again I am not an expert at this, but would appreciate your opinions on this. Thanks!
Old 01-19-2015, 04:27 PM   #14
shibbs
Captain Gingerbeard
shibbs's Avatar
If you don't have any pulsating while braking, I wouldn't resurface the rotors.
Maybe take some sandpaper to the rotors to buff them up a bit, then MAKE SURE TO BED IN THE PADS PROPERLY.
40mph BRAKE HARD to 5mph. It's important to NOT COME TO A COMPLETE STOP DURING THIS! Right away back up to 40, then down to 5, then again. Then take the speed up to 55 and down to 5 three times. Then drive nicely - as little braking as safely possible for about 15 minutes at highway speeds to let everything cool.
