Old 09-04-2013, 04:22 PM   #1
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
JBA Long Tube 1 7/8" headers - How is the quality??
I was looking at doing an long tube header setup and there are a lot of favorite brands out there. Kooks, ARH, to name just a couple off hand. I hear they are top quality. But others in the past have said JBA made quality stuff. But I have searched and not a whole lot of people talk about the Long tubes.
For the people that have them, how was the fitment and quality on them?
They have a nice V-band clamp at the outlet where the connection pipe goes to the catback with either high flow cat or no cats. I will be running the high flow cats and stock catback with the setup. Can I get some feedback from owners that have them installed. Does the V-band style sealing mechanism seal without leaks. Any issues with install.
Thanks in advance for any feedback.
Brian
1LE Red Dragon is offline   Reply With Quote
Old 09-04-2013, 04:29 PM   #2
Motion427
Drives: 2010 2SS/RS Red Jewel L99
I have a car at the shop right now that has a set of JBA long tube headers.
From what I see,they seem to be pretty decent.Fitment seems to be nice.
Motion427 is offline   Reply With Quote
Old 09-10-2013, 04:11 PM   #3
SS 376
SS 376's Avatar
Drives: 2010 IBM 1SS (Former)
Brian
I bought a set of JBA LT headers for my SS. One side didn't fit--if I recall correctly, it was off by half an inch to an inch. My tuner, who is pretty reputable, said JBA was low quality, and recommended Kooks or American Racing. Then I had to fight to get a refund--they just wanted to give me a new set of headers. If I had it over again, I would've spent the extra money to get Stainless Works or Kooks headers.
SS 376 is offline   Reply With Quote
Old 09-10-2013, 10:12 PM   #4
MightymouseSS
Drives: 2011 LS3
If your looking for a good set of headers at a good price you can't beat stainless power made by stainless works.
Stainless Works Headers
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Tuned by Southwest Speed
MightymouseSS is offline   Reply With Quote
Old 09-10-2013, 10:17 PM   #5
MightymouseSS
Drives: 2011 LS3
Btw I had a set of jba shorties before my lts never had an issue.
Vmax TB
SLP loudmouth 2
Nightfury Cam
Mike Norris CC
Old 09-10-2013, 10:46 PM   #6
Sugarfree135
Drives: 2011 2SS/RS
I'm about to install some on Friday/sat so ill let you know 😉
Sugarfree135 is offline   Reply With Quote
Old 09-11-2013, 07:57 AM   #7
1LE Red Dragon
Train Driver
Great. Interested to hear how they fit.
Old 09-11-2013, 09:02 AM   #8
Sugarfree135
Drives: 2011 2SS/RS
Yeah me too 😳 I'm interested to see wether I have immediate check engine lights or can go a few hundred miles like others. Ill be running the catless midpipes though so i may preemptively do the spark plug anti fowler mod to possibly help out 😝
Old 09-11-2013, 10:26 AM   #9
2010 4 DW
Drives: White 2010 RS/SS
Brian
Check out the article below as you can see images of how they fit the car. I have the JBA LT's on my car and they fit like a glove and I have had NO issues.
http://www.camaroperformers.com/cama...car/index.html
2010 4 DW is offline   Reply With Quote
Old 09-11-2013, 10:08 PM   #10
Sugarfree135
Drives: 2011 2SS/RS
Ok nm I forgot that the ones I got were 1 3/4 not 1 7/8's so my figment probably won't reflect yours
Old 09-13-2013, 09:38 PM   #11
Indyblue98
2012 RS 2ss
Drives: 2018 ZL1 2012 2SS WhippleCharged
Put them on using jackstands. Did have to shorten a couple of the threaded studs that hold insulation in place , otherwise it went smooth and a year later they still look great .
2018 ZL1 A10 and 2012 2SS RS Whipple-Corsa-RotoFab-ZL1 Diff 3.73 Pfadt ZL Stage 3 Suspension+
Indyblue98 is offline   Reply With Quote
Old 09-14-2013, 11:09 AM   #12
EOD
EOD's Avatar
Drives: 1968 Camaro SS & 2015 GMC Sierra De
I've had JBA 1 7/8" headers on my car for 25,000 trouble free miles. They fit great, the car sounds amazing, and I've made pretty good power through them. My vbands have never leaked as long a I have made sure that everything was lined up perfectly be tightening. One of the studs on the vband did break once while I was removing the exhaust to install my clutch. Install is easy, directions say to remove the steering shaft, but you can get them in with out doing that.
Whipple SC, Lingenfelter Heads & Cam, ACT Twin Disc Clutch, Rotofab CAI, JBA 1 7/8" Long Tube Headers & 3" Exhaust, Livernois Motorsports Fuel Pump, DSS 1400Hp Axles
RWHP 660
RWTQ 618 SOLD
EOD is offline   Reply With Quote
Old 09-17-2013, 08:34 PM   #13
epstein
Drives: SS/RS
Send a message via AIM to epstein
where did you get another v band?
are you running any material between header and cat/test pipe?
epstein is offline   Reply With Quote
Old 09-17-2013, 10:55 PM   #14
Sugarfree135
Drives: 2011 2SS/RS
I put gaskets in between mine when I initially thought I had a leak but it was just the natural header noise 😜
