Old 05-23-2014, 03:39 PM   #1
meatmeat
meatmeat's Avatar
Drives: batmobile
Need to know how serious
Have anyone seen the display error/message
Batman should drive a camaro
(not my car)
meatmeat is offline   Reply With Quote
Old 05-23-2014, 03:45 PM   #2
Enduring
Enduring's Avatar
Drives: 2013 2SS/RS M6
The StabiliTrak isn't working any more and is turned off, so you no longer have the benefits of it. The car will drive fine under normal conditions but if you push it too hard, to the point where StabiliTrak would normally kick in, the StabiliTrak won't kick in and you may lose control. It is something that you should get looked at in case you need the benefits of StabiliTrak in an emergency situation.
Enduring is offline   Reply With Quote
Old 05-23-2014, 03:48 PM   #3
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
At least it ain't overheating! Sometimes 1 sensor failure can make multiple lights come on. I would take to a mechanic shop that you use. Was the TPMS light already on?
Old 05-23-2014, 03:49 PM   #4
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
usually traction control issues, like unexpected wheelspin..should go away when you turn ignition on/off and/or after driving a few miles.
Old 05-23-2014, 04:17 PM   #5
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
What year is it? There could be a TSB for the problem.
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 05-23-2014, 04:40 PM   #6
meatmeat
meatmeat's Avatar
Drives: batmobile
My car is a 2011. And is the TMPS light was already on. I don't have the sensors in these tires. Thanks for the info
(not my car)
Old 05-23-2014, 10:54 PM   #7
4510
Drives: 2013 2SS/RS Rally Yellow
Funny you should ask. With 800 Miles on my new 2013 2SS... I am stuck in Missouri because that came on.
My symptoms... the car started bucking like it had a plugged fuel filter (60MPH at the time) and then that error message.
I shut down the system and then drove to a rest stop and sorted out where a dealer was.
Started car all was good... 10 minutes later a slight buck, same error message and the car shutdown the traction control, Tach died, lights all over the place. Drove the car into the dealer.
Surprisingly enough the dealer that is awaiting the part says the error codes they retrieved say Crank Angle Sensor is bad.
Long way from home, with a brand new GM Boat Anchor.
2013 Camaro 2SS/RS-6spd- Rally Yellow / AGP Twin Turbo
2015 Challenger Hellcat-6spd- Sublime
I think I see a trend here....
4510 is offline   Reply With Quote
Old 05-23-2014, 11:49 PM   #8
LIyellowSS
Drives: 2012 SS, had 1995 Z28
I just had the same issue, the Throttle body sensor needed to be changed. It was covered under warranty but before I got to the dealer, 3 days later, it made the car run on only 4 cylinders while the warning was on. I was able to turn the warning off by turning the car off and letting it sit for 5 minutes or so. I had to do this 3 times in the days waiting for my appt with the dealer. My CEL was also on but turned off after a few starts.
LIyellowSS is offline   Reply With Quote
Old 05-24-2014, 02:20 AM   #9
dgriddick
Drives: 2011 Camaro SS/RS
I had the issue after installing console gauges. I reconnector under the shifter cover forward of the shifter and reconnected the switch to reseat it.. no more issues
dgriddick is offline   Reply With Quote
Old 05-24-2014, 04:50 AM   #10
NYCamOwner
"Katy"
NYCamOwner's Avatar
I meant that there could be a known issue with it that GM has recognized and is willing to fix. It has nothing to do with "sensors in the tires". I just went through that with my car, the CEL light would come on and would get decreased power, then it would go out. Just before I had it looked at, the "Service Stabilitrack" light came on also.
I posted the TSB in another thread if you are interested to see.
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
Old 05-24-2014, 08:23 AM   #11
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
Well this what happens when cars today are 90% filled with electronic sensors. And top it off who knows who is manufacturing these parts? Way back when, parts were either made in house or sourced out to a supplier across town. Now thanks to our new "GLOBAL" economy these parts are probably filled lead and mercury and coming from China, Japan and Mexico.
shrinkdoc is offline   Reply With Quote
Old 05-24-2014, 09:01 AM   #12
usnatclee
usnatclee's Avatar
Drives: '12 2SS/RS, '13 Vette, '13 Wrangler
Did you recently change your wheels and tires? That can cause it if you're too far from the stock size.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned.
ROCK CHALK JAYHAWK GO KU!
usnatclee is offline   Reply With Quote
