Old 06-01-2014, 02:55 PM   #1
crc91
crc91's Avatar
Drives: '14 1LS
Ark cat backs vs corsa
Been checking out some exhaust clips of the two ark cat back setups and the corsa. I like the zero drone concept and quality corsa is known for. I'm concerned it won't be much of a change from stock though. I like an aggressive exhaust note some high way drown is ok but a lot of it isn't cool lol. I have a 14 1ls. High flow cats from solo will be accompanying which ever set up is chosen. Can somebody also explain the difference between both ark catback set ups?
crc91 is offline   Reply With Quote
Old 06-01-2014, 05:05 PM   #2
markkk
markkk's Avatar
Drives: 2012 Camaro 1LS
The N-2 is slightly higher pitched than the DTS
I just got the N2 and love it.
markkk is offline   Reply With Quote
Old 06-01-2014, 05:08 PM   #3
markkk
markkk's Avatar
I also bought the DTS tips, which I'm going to get a friend to weld on soon!
Old 06-02-2014, 09:52 AM   #4
crc91
crc91's Avatar
Drives: '14 1LS
So is the n2 more aggressive or just sound more rev-ish? What's the difference in the tips if you don't mind me asking
Old 06-02-2014, 01:54 PM   #5
markkk
markkk's Avatar
The N-2 has an aggressive sound, although it does not have an extremely deep rumble, it sounds more sporty in my opinion, although I love it. The tips don't make it any different, just a different look. I like the burnt tips better than the slanted tips.
Old 06-03-2014, 01:43 AM   #6
crc91
crc91's Avatar
Drives: '14 1LS
Gotcha thanks man! Do you think the n2 with high flow cats would be too loud?
Old 06-03-2014, 07:55 AM   #7
fsusmithc2
Emerald Coast Camaros
fsusmithc2's Avatar
Drives: 2017 2SS A8 50th Anniversary
Nope.
I have the N2 setup with Solo HFC and love it. To my ears, it only got a tiny bit louder than it already was and believe me, from a dB standpoint, I've heard much louder. When I was looking around for the note I liked, Ark N2 hit the spot. Second choice would have been MRT V2 but a deal arose which helped tip the scales and I never looked back.
If you look me up on YouTube (same username), I have some dragstrip videos and also one before and after installing the HFCs. I have to confess though the after result sounds louder in that video because the rear of the car was facing into an enclosed car wash bay and the before was outside. Just ignore the warmup part and how echo-y it sounds and you'll get the idea.
http://www.youtube.com/fsusmithc2
The main difference, structurally, between the N2 and the DTS is the N2 has 2.75" pipes w/o resonators and the DTS uses 2.5" pipes and has resonators. Ark's site says the N2 puts out 92db @ 3000rpm and the DTS weighs in at 90db at the same rpm.
The drone spot is right around 2k rpm, which is at or near where you'll be when cruising on the highway. It is audible in-cabin but it doesn't bother me much. I'm certainly not dissapointed. It's a performance car. It's going to be loud.
Another edit, if it helps, here's my SOLO HFC install thread w/ pics: http://www.camaro5.com/forums/showth...t=solo+install
Current: 2017 2SS 50th Anniversary (#350)- 12.22 @ 115mph
- MX0 8-speed automatic, CF5 power sunroof
Former: 2012 1LT/RS A6 - 14.11 @ 99.75mph
Order: TMFF65
1100 - 5/19/16 | 2000 - 5/26/16 | 3000 - 6/1/16
3100 - 6/6/16 (TPW 6/20) | 3300 - 6/9/16
3400 - 6/10/16 | 4200 - 6/23/16 | 4300 - 6/28/16
5000 - 6/30/16 | 6000 - 7/1/16
Club F1FTY
fsusmithc2 is offline   Reply With Quote
Old 06-03-2014, 02:32 PM   #8
crc91
crc91's Avatar
Drives: '14 1LS
Thanks man I checked it out it sounds good, I wanted to ask you if I could request a video? If it's too much a pain in the ass I understand! I'd just hate to put on the exhaust and hfc (I'm doing a CIA cold air intake as well) and have the car sound like a high strung vs engine from the 350 and 370 zs they sound awful under hard acceleration!
Old 06-04-2014, 08:03 AM   #9
fsusmithc2
fsusmithc2's Avatar
Actually I should have mentioned that I also have a CAI intake and it was on in all of those videos. It was the first mod I did so it's been on a while.
What kind of video are you looking for?
Order: TMFF65
Club F1FTY
Old 06-04-2014, 10:56 AM   #10
crc91
crc91's Avatar
Drives: '14 1LS
Mainly looking for a start up and a drive by. If you could do a few seconds in cabin like on the highway that'd be a bonus. Again only if it's not to much trouble!
2014 1ls, ark catback, corsa catback, exhaust, lfx v6
