Old 06-17-2014, 04:50 AM   #1
rtg
rtg's Avatar
Drives: 2013 ZL1
Stabili-Trak Fault Warning
Went around a corner yesterday. Back end kicked out a bit. Traction control light came on then the DIC indicated the fault. All three indicators on the display came on and stayed on.
No response to controls. Scanning the car showed no codes while the Stabili-trak fault was being displayed.
Shut the car down for several hours. When restarting the fault was cleared and traction control worked as normal.
Anyone one else seen this?
Rob
2013 ZL1 VR
rtg is offline   Reply With Quote
Old 06-17-2014, 05:57 AM   #2
NYCamOwner
"Katy"
NYCamOwner's Avatar
Drives: 2014 2LT A6 'Vert
Rob
Which 3 indicators? What was the message on the DIC?
2014 Black 2LT Convertible
Elite Engineering Catch Can, Vitesse Throttle Controller, CAI Cold Air Intake
Possible next mods:
Throttle Body
Exhaust
Upstate C5 Member
No, that is not me in the avatar..... I just love hot girls and hot cars.... or hot girls IN hot cars....
NYCamOwner is offline   Reply With Quote
Old 06-17-2014, 11:50 AM   #3
rtg
rtg's Avatar
Drives: 2013 ZL1
From memory:
Lights - traction control off, traction control active, and small engine.
The DIC said, "Stabili-Trak" fault....
Rob
2013 ZL1 VR
Old 06-17-2014, 12:38 PM   #4
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
I've had a warning in my DIC come on before that said, "Service Stabilitrak" and my stabilitrak, traction control, and ABS lights all came on while the dash speaker kept dinging at me. If I tried to go more than 55mph or if I tried to hard accelerate while all the lights were showing the acceleration would be sluggish or the throttle would be jerky and weird. And this was out of the blue, not even after any kind of aggressive driving.
Then, if I turned the car off and let it sit for a few hours, everything reset and it drove like normal.
Very odd behavior, but whatever.
My VIN = 2G1FK1EJ9A9105017
Old 06-17-2014, 02:55 PM   #5
rtg
rtg's Avatar
Drives: 2013 ZL1
I should have taken a picture but I think you are right it must have indicated, "Service Stabilitrak".
Thanks,
Rob
2013 ZL1 VR
Old 06-17-2014, 02:56 PM   #6
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
I've got the Traction and Stabilitrak lights on before when I whipped it around a corner but shortly after the lights turned off.
Knockoutpie is offline   Reply With Quote
Old 06-17-2014, 03:03 PM   #7
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I have seen it occur with our Suburban when the brake fluid was a little low. Have not had it occur with the Camaro, but I watch the brake fluid carefully.
Don't overfill your brake fluid if it is lowish. It seems to leak out of the cap if too full.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 06-17-2014, 03:56 PM   #8
Mannsiam
Mannsiam's Avatar
Drives: 2014 Camaro 1SS/RS 1LE
Mine came on after coming off a dyno. Just let is sit for 10 min started up and all was good.
Yeah Im a Chevy Guy. 11 Silverado, 12 Malibu, 14 Camaro 1LE
Mannsiam is offline   Reply With Quote
Old 06-17-2014, 07:28 PM   #9
usnatclee
usnatclee's Avatar
Drives: '12 2SS/RS, '13 Vette, '13 Wrangler
Have you changed your wheels or tires lately to other than standard?
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". Custom exhaust, RX oil catch can and oil breather, CAI inc intake, SLP 160* thermostat, TSP 2" LT headers w/ off road pipes, custom cam, tuned. 467rwhp 450rwtq.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned.
ROCK CHALK JAYHAWK GO KU!
usnatclee is offline   Reply With Quote
Old 06-17-2014, 07:30 PM   #10
usnatclee
usnatclee's Avatar
Happens every time you dyno the camaro. It sees the rears spinning and not the fronts and thinks something is wrong.
Old 06-17-2014, 07:56 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
+1
Mods:
Old 06-17-2014, 08:08 PM   #12
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
I don't do any spirited driving with the nannies on normal. I'm sure they are complaining if you are trying to do tricks like kick the rear out and you have them set in normal mode.
Then the traction control loves to chop the throttle. I'd rather drive the car myself personally.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 06-17-2014, 08:11 PM   #13
two_wheel_mayhem
Would it still do that if you turned it off before the session?
Old 06-17-2014, 08:54 PM   #14
13umble13ee
13umble13ee's Avatar
Drives: 2012 1LS V6 LFX
I am sure we all are aware that if you push the button for 7 seconds it turns all assists off. that would solve the dyno issue.
I had this happen to me right after I got mm baby. I stalled it and quickly restarted and gunned it and my assists lit up like xmas. (due to the fact I didn't let the computer do the start up check) After talking to the dealer I came to the conclusion that if the assists are engaged and haven't reset to normal and then engage again the system freaks out and they stay on. Turning the car off for 30 min or more will clear it out.
13umble13ee is offline   Reply With Quote
