01-18-2015, 10:54 PM | #1 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
Will these fit my 2010 SS RS?
I have to go with wider tires on the back of my 2010 2SS RS with Brembo brakes, etc. I have switched to the heavier duty rear axles, but otherwise the suspension is 100% stock.
Will these wheels fit? Did I have to modify anything? Did I need spacer plates? How wide of tires can I use on the rears? 305? 315? 5x120 mm bolt circle front: 20x9.5 +35 mm offset rear: 20x11 +40 mm offset
Jack Bilger
