02-02-2015, 06:22 PM | #1 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
*HELP* running too lean
i went to autozone today because my CEL keeps coming on and off and the codes i got were P0102 and P0104 bank 1 and 2. it was saying how it was running too lean. also the CEL came on a day after i installed a elite catch can and RX breather. everything is capped off so i am not sure how i am getting these codes any help is appreciated.
02-02-2015, 07:13 PM | #2 | |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
02-02-2015, 09:27 PM | #3 |
02-02-2015, 09:43 PM | #4 |
First thing I would do is remove the breather and leave the catch can, that will see if the breather has a busted valve.
02-02-2015, 09:48 PM | #5 |
Okay I will try that tommorow and see how it works out, also would I have to plug in the thing were I have the two sides capped off one on the Intake and the other in the back of the engine?
02-02-2015, 10:04 PM | #6 |
Yes, that is how metered air goes through the crankcase and to the manifold. The breather allows unmetered air in, but is supposed to limit it to prevent codes. Yours might have a bad valve, might need cleaning.
02-02-2015, 11:36 PM | #7 |
thanks for the help, i will check it out tommorow.
