09-17-2014, 09:11 PM | #1 |
Under construction...
Drives: Black 2012 2SS Join Date: Jul 2014
425rwhp goal help
Okay so I have a stock 2012 SS LS3 which is good for 362rwhp, I want to get that number up to at least 425! I plan on doing the LS9 cam swap which they say adds 20-30hp and a Airaid CAI which is like 5-10hp so I'll be between 387hp and 402hp. I would love to keep my warranty intact so what are some other mods I can do to reach my goal? Like I said preferably keeping warranty intact...
2012 2SS/RS, mods coming soon
09-17-2014, 09:14 PM | #2 |
Ride On!!!!
Exhaust
09-17-2014, 09:15 PM | #3 |
Catback? What brands have the best gains?
09-17-2014, 09:26 PM | #4 |
Drives: 2013 AGM 1SS/RS LS3 Join Date: Mar 2011
Long tube headers (with or without cats), Ported Throttle body, an aftermarket air intake, exhaust, and tune. I have a 2013 LS3 and right now I'm sitting at 424rwhp. I wouldn't bother with the LS9 cam. It will realistically gain you about 18-20rwhp.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts |
09-17-2014, 09:26 PM | #5 |
Drives: Camaro and Sierra Join Date: Jul 2012
If you're doing cam add headers as well
09-17-2014, 09:27 PM | #6 |
I don't believe header keep warranty? So if I ever do header it will be after I've tried all other warranty friendly items...
09-17-2014, 09:28 PM | #7 |
Drives: 2013 SS Join Date: May 2013
You just want to have the number or want it to perform?
09-17-2014, 09:30 PM | #8 | |
Hide! My wife's coming!
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2011
Doing the CAM will void your warranty. Like the others have said, Ported TB, headers, catback, CAI and a good tune should put you easily over 400 on the LS3. If your going to do a CAM, your better off going with something with better gains. Not worth the money to go LS9 unless your doing the labor yourself.
2013 Camaro ZL1 Convertible CRT - 630 RWHP / 620 RWTQ - ADM Performance Built/Tuned - ZL-700 Package - LS9 CAM - Lingenfelter CNC Ported Heads - Stainless Power Headers
09-17-2014, 09:30 PM | #9 |
Well how different does a bad 425whp perform compared to a good 425whp?
09-17-2014, 09:32 PM | #10 |
If I get the LS9 cam at the Chevy dealership it would keep my warranty right? If not I'll probably not get to 425 with warranty
09-17-2014, 09:32 PM | #11 |
Drives: 2011 LS3 Join Date: Jan 2012
Only way you'll get 425rwhp is full bolt ons(cai, lt headers, ported tb, tune) and thats pushing it. The tune will void your warranty. I dynoed 400/398 with bolt ons and stock tune before getting cammed. Getting a cam will definitely get you those numbers but you pay to play if warranty is that important look into solo hf cats but you wont get anywhere near the 425 rwhp. As for the ls9 cam we'll thats gonna void your warranty as well so if your already going to go through the trouble might as well go big.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
09-17-2014, 09:36 PM | #12 |
Okay well it looks like no warranty for me, guess I'll get as far as I can on warranty friendly item then when I hit the wall I'll make the leap
09-17-2014, 09:40 PM | #13 |
I thought the same way and ended up spending more $$$ by doing things twice. I went with jba shortys and gained hardly anything. I sold those for cheap to a buddy and got LTs and it made a huge difference. If I knew then what I know now I would've save some time and money.
09-18-2014, 06:39 AM | #14 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Sadly there is no way around this, or we all would have found it by now. If you want more power and want the car to 'perform', as stated above you HAVE to re-tune the ECM to calibrate it for all the changes. Sadly that is just the cold reality. These engines have been around a long time and have proven reliability even after modded, if done right and tuned right. I appreciate your outlook though, if you cant pay to fix/replace then you should not MOD. Good luck OP, but trust me you wont regret modding if/when you do!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
