04-17-2012, 01:48 AM | #1 |
Drives: 2010 2SS/RS Victory Red Join Date: Mar 2011
Disconnecting battery?
What preset info do you lose, if any, when disconnecting the battery?
Bluetooth? All the settings you use your radio to set up?
21 years of owning Camaros. Finally got a 5th Generation. |
04-17-2012, 04:04 AM | #2 |
Camaro Owner & Enthusiast
Probably depends on for how long... I had my battery disconnected for 2 full days during a car show and all I had to do is re-index the windows. If you're gonna disconnect for an extended period, a lot of people will tell you to get a battery tender.
04-17-2012, 06:36 AM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
It all depends on WHERE you disconnect the battery. As Diehard was talking about, he disconnected his battery for a indoor show (I was at the same one) and we had to disable the starter by disconnecting the battery, which you can do UNDER THE HOOD. IF you disconnect it there, you will lose nothing, in fact you can still run all your lights, play the radio, lock and unlock your doors, everything. NOW, if you disconnect the power AT THE BATTERY in the back, as in take the battery out kind of thing, you will end up losing all your settings on your radio, but you will retain everything in your phonebook.
04-17-2012, 06:57 AM | #4 |
Drives: 2011 2SS/RS, '22 Silverado Z71 Join Date: Sep 2010
Yeah, I disconnected my battery overnight (10-12 hrs) when I had an issue with my CAI and the fuel trims. After reconnecting, I had to reset the radio--- time and stations......my voice and phone settings were kept. The computer did the rest when it ran for awhile.
04-17-2012, 07:14 AM | #5 |
I want to pull the steering wheel bezel and disconnect the airbag. So, disconnect the battery at the under the hood point?
04-17-2012, 07:15 AM | #6 |
"SHARK" Born Apr.26,2011
Drives: 2011 CGM 2LT/RS Convertible Join Date: Oct 2011
For winter storage purposes. I did a negative terminal disconnect where the battery is located in the trunk.
after rehooking up here is what I lost. obviously power everywhere was shut off. be careful with the trunk, don't shut it fully as powerbuttons for trunk opening won't work. window indexing. re-set time on clock (I did not have any radio stations preset) compass had to recalibrate itself. I can't recall if my phone book was intact..sorry. but that's about it. Last edited by '11 cyber grey vert; 04-17-2012 at 09:23 AM. |
04-17-2012, 07:37 AM | #7 |
NO.....to do that you need to TOTALLY kill power to the car.....so you will need to disconnect the power AT THE BATTERY. otherwise you would still have power at the steering wheel and considering what you are going to do, you don't want power to teh wheel, or if you do something wrong, it could go off on ya....and thatwould RUIN your day.
04-17-2012, 07:43 AM | #8 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
I disconnected my battery for 6 months for storing it and the only info i lost was I had to reset the time and tire pressure guage and the compas had to calibrate. I DID NOT have to reindex my windows or reset my preferred stations or bluetooth or anything.
04-17-2012, 07:59 AM | #9 | |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
04-17-2012, 08:09 AM | #10 |
Drives: 2012 2SSRS/M6 SIM Join Date: Apr 2012
Re-index your windows? I don't have my ride yet but what do you mean by re-indexing?
04-17-2012, 08:29 AM | #11 | |
Michael............
04-17-2012, 09:14 AM | #12 |
ahhhhhh its Sir NUKE......not Duke...lol bt your welcome.
04-17-2012, 03:45 PM | #13 | |
Drives: 1985 Chevrolet, Black Join Date: Apr 2012
The same thing happened with me
04-18-2012, 02:13 AM | #14 |
TREMEC6060 1-2 needs fix
Drives: 2011 2SS/RS Join Date: Jul 2011
When I had a cam and headers done on my 2011 2SS the battery was disconnected for a day or two, (or three). I had to reset the windows by lowering them down all the way, and then all the way back up. The message came up on the center digital info display between Speedometer and Tach. And I had to do it for passenger and driver side, twice for each. That was to calibrate the windows for open and closed door. The windows drop down about half an inch when you open the door, and then go back up when you close it. They have to figure out how much to lower and raise and save those settings in the Body Control Module, (BCM). The BCM is like the ECM, (Engine Control Module), it's a dedicated computer that controls all the body stuff not related to engine and power train, like the air conditioning and lights, and door locks and so on. I lost all radio station settings, but it kept my bluetooth phone connection. I have no idea why, maybe some things, like Bluetooth, are burned into eeprom and others, like radio station settings, just into regular RAM that erases when it loses power.
Asimov's Fourth Law of Robotics: If you don't know what else to do, wave your arms and run around in circles.
Thread Tools | |
Similar Threads | ||||
CTEK US3300 $69.99 - Free Shipping and Free Cig Lighter Adapter! | Double D Mods | Audio / Visual / Electronics/ Gauges / Nav | 6 | 06-06-2012 06:29 AM |
CTEK Multi US 3300 Battery charger available at www.gmpartshouse.com | patrickt | Audio / Visual / Electronics/ Gauges / Nav | 15 | 03-02-2012 02:20 AM |
Disconnecting neg battery for CAI install? | Cincy10SSRS | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 8 | 08-01-2011 07:45 PM |
Disconnecting battery VS Fuse pull | Nessal | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 07-26-2011 04:46 PM |
disconnecting battery to change a magnaflow exhaust? | faninc | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 10 | 03-04-2010 08:03 PM |
