11-24-2012, 01:01 PM | #1 |
Drives: 2010 2SS/RS Victory Red Join Date: Mar 2011
JBA LT header install parts question
I bought a set of JBA LT's but there is no installations hardware except for the clamps to connect to the HF cats.
Can I use the OEM exhaust manifold bolts? Where can I get a set of new gaskets? Is there any gasket between the LT's and HF's that needs to go in before the clamps? I appreciate any help. Anything else I need parts wise? Michael...... I have found some O2 extensions.
21 years of owning Camaros. Finally got a 5th Generation. |
11-24-2012, 04:15 PM | #2 | |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
I'm not familiar with the JBA LT's so I can't answer that second question, but I would take a guess and say no. Parts wise, the box should have come with 02 sensor extenders, bolts and gaskets, but as I mentioned before, use the OEM stuff. |
11-24-2012, 05:53 PM | #3 |
You're better off reusing the factory gaskets for sure. I don't think any headers on the market comes with new header bolts either so that is something else that gets reused regularly. Pretty sure JBA headers are clamp on so there is no gasket between the headers and connection pipes. You'll just need the clamps.
11-24-2012, 07:30 PM | #4 |
Ok, great. I appreciate the responses.
These headers were bought second hand. Thanks, again. Michael............
11-27-2012, 10:07 AM | #5 | |
Drives: White 2010 RS/SS Join Date: Dec 2009
11-30-2012, 07:35 AM | #6 |
I'll assume you are DW with JBA. THANKS SO MUCH for the install kit and instructions. YOU GUYS ROCK!
Thread Tools | |
