11-16-2013, 03:49 PM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Oct 2013
Anything special to know when installing exhaust upgrade?
Hey guys.
I have a friend who works on older cars and I asked him if I bought the exhaust upgrade from Chevy performance if he could install it he said yes but he worries about it being effected by the ECM etc. Is there any worry or is it simply uninstall one put the other? |
11-16-2013, 03:54 PM | #2 |
Drives: 1ss in Blue Ray Metallic Join Date: May 2013
Could you specify what 'exhaust upgrade' you're reffering to?
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
11-16-2013, 03:56 PM | #3 |
Drives: 2011 SIM 2SS/RS LS3 Join Date: Sep 2013
Cut off the old and weld/clamp on the new.
2011 2SS/RS built 8/24/10
11-16-2013, 04:57 PM | #4 |
Master of Nothings
if you're buying from ChevyPerformance i would guess that they wouldn't send you something that's not going to fit or work properly, but then again...
2010 Chevrolet Camaro 2LT/RS |
11-16-2013, 05:06 PM | #5 |
Drives: 2012 1SS Black with white rally str Join Date: Jul 2011
As long as it is a cat-back or axle-back system, it should not affect the ECM.
It's good to be the King.
11-16-2013, 05:55 PM | #6 |
Drives: 2013 Camaro 2SS A6 vert Join Date: Nov 2013
Here's what you need to know about exhaust on our cars.
1. Long tube headers will make you the most power (20-40 HP on an SS), amp up your exhaust note slightly and will require a professional dyno tune to make the most gains and reset your O2 sensor light. Short tube headers won't give you much of anything (5-10 HP maaybe) 2. Catbacks will give you 5-10 HP and will effect your sound the most drastically and dynamically depending on brand, doesn't require a dyno tune 3. Long tubes and high flow cats will require a tune and will almost always give you heavy and bassy cabin drone from 1000-2500 rpms compared to stock. This is because the accoustics of the original x-pipes and mufflers were sound engineered for noise cancellation. The way around this would be to custom fab some J pipes after you install and figure out what rpm your max drone is at, one capped j pipe for each exhaust pipe. Basically it depends how loud you want the inside of your car to be, whether or not you're naturally aspirated, and whether you're going for power gains or aethetics. Personally, I've run headers and experimented with different catbacks in the past but since my car is a DD, choose now to run only headers on stock exhaust. Sounds like a beast at WOT and keeps me sleeping from the cops when I don't feel rowdy ; ) Personal preference and goals are all it comes down to. Good luck!
K&N CAI, VMAX PTB, Kooks 1 7/8 LT Headers w/ Kooks high flow cats, dynotune, LPE 3.70 rear end gears --- 390 RWHP 405 RWTQ
11-17-2013, 04:00 AM | #7 |
your talking about these? http://www.gmpartsdirect.com/results...umber=92206992
you just cut your mufflers off with a sawzall or exhaust cutter and clamp on the new mufflers. easy. just dont cut off to much
11-17-2013, 10:31 AM | #8 | |
Drives: 2010 RJT 2SS M6 Camaro Join Date: Feb 2011
You didn't mention whither you have a LS3(manual) or L99(automatic). If you have a LS3, just put whatever you want on it. Stay behind the catalytic converters and you're good to go. If you have a L99, you will need to disable AFM or be very careful on your exhaust selection. If you disable AFM with a tune, again, your warranty will be voided. But you can disable AFM with a Range device and keep your warranty intact. Hope this helps.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
