Old 03-02-2020, 11:39 AM   #1
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Need help with ABS
Some mice chewed up my insulation along the passenger side firewall. I already removed the 2 plastic nuts. However, there is a bracket that holds the lines running to the ABS module. I’m having a difficult time seeing if there is a bolt or screw that’s holding the bracket in.
Thanks.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
