Old 11-17-2013, 09:34 PM   #1
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Trans Temp When Cold
What is the transmission temperature supposed to be at cold startup? I installed a GM 4-gauge cluster in my 2011 1SS LS3 a couple months ago and the trans temp gauge always reads about ~80 degrees on a cold startup (even after a full day of being parked). Is this normal? What does your gauge show when cold?
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 11-18-2013, 06:12 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
It supposed to be the temperature of the transmission at start up. You live in a desert. It's normal. If you lived in Alberta, Canada, it would not be normal.
TheHorse13 is offline   Reply With Quote
Old 11-18-2013, 06:53 AM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
To think about it the fluid gets hot driving. When turning off the car the transmission will slowly cool, but it is tucked up in the underbelly of the car with a heat shield above it. So it is going to stay warm for a long time. Heat rises but it does not have anywhere to really rise to under the car so it has a warm thermal layer that stays there for a long time.
Scott@Bjorn3D is offline   Reply With Quote
